Old 06-24-2015, 07:58 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Wheels and Tires
Print Wikipost
HELP! Front tyre inner edge dramatic wear???
Old 09-27-2014, 04:12 PM
Larkoth's Avatar
E-Class
Hi, i'm fairly new here but i really need some help, i have included a picture of one of my front tyres, this is the wear that has been happening on both front tyres on the inside edges, please can anyone give me a clue as to what is causing this, this tyre has done less than 10k miles, the car is a completely stock W212 E200 Sport, the tyres are Continental Contisport 18" tyres that were factory fitted (i stayed with the same tyres)
i am grateful for any help (i have posted on another section of the forum i hope i've posted in the right sections)
thanks in advance
Old 09-27-2014, 04:20 PM
belarus27's Avatar
2010 e550 p2
alignment?
Old 09-27-2014, 04:31 PM
Larkoth's Avatar
E-Class
i had new tyres fitted on wednesday and they said that the camber, etc was all ok, i have just taken off that same wheel today (it was losing air due to a puncture) and the wear on the inside edge has already started to wear a groove that is noticeable (this new tyre is only 3 days old) the garage want to do a four wheel alignment check, but this was carried out after the last tyres were changed and, well, look at the picture, i guess it didn't work, so i'm not sure whether i should let them charge me £80 to do it if it's not going to work
Old 09-27-2014, 05:00 PM
pamiboy's Avatar
E 350
I think its time to change your tire alignment "garages / service centers" first.
Old 09-27-2014, 05:23 PM
Larkoth's Avatar
E-Class
yeah i was thinking of going to a tyre garage that don't do anything else, i guess they might be the best to sort this out cos tyres are expensive and they are getting damaged quickly.
so is the tyre rubbing on something? this surely cannot be road wear can it? it just seems too far on the side to be the road
Old 09-27-2014, 07:12 PM
imaphaetonguy's Avatar
GLC300
I had this exact problem on a 1 yr. old Lincoln that had prematurely worn the tires exactly like yours.
Turned out the culprit was bad motor and transmission mounts. These were eventually recalled by Ford, and replaced both engine and tranny mounts. They are basically a rubber pad that is sandwiched between to pieces of steel to absorb vibration.
This could also explain why the alignment was in spec, while the car is stationary and being checked for calibration. The wear came from the uneven side to side load of the engine moving while driving.
Have those checked.
Old 09-27-2014, 09:07 PM
Larkoth's Avatar
E-Class
thanks for that information i will pass that on to the garage and see if they can check that for me
Old 09-27-2014, 09:55 PM
PeterUbers's Avatar
Received 1,881 Likes on 1,319 Posts
2014 E63S; AMS 100 octane ecu tune; edok tcu tune; BB intakes; dyno tuned
That tire has less than 10k miles on it?? it looks TERRIBLE!! it's cracked, worn throughout (not just the outside rim) and just in crappy shape .. a 10k mileage tire should look WAAAY better than that -- something is not right with your alignment despite the shop's recommendation (agree with the above member stating to find another shop) ..
What does the tire look like ON the vehicle -- any pictures of the stance of the vehicle from the off-angle view to grossly evaluate the camber?
In 10,000 miles you're already down the the wear indicators... i'd expect this from an E63 rear tire set when the E63 is driven aggressively every day .. not from an E200...
Wishing you good luck in finding a fix for this. Please update us when you find a solution
Old 09-28-2014, 05:27 AM
PHML's Avatar
2011 GLK350 P1, Multi-media & AMG Pkg; 2010 E350 w/ prem 2; 2018 4Runner SR5 Prem. 4x4
If not the camber, then check the toe...might be toe in since its inner tire wear.
Old 09-28-2014, 03:25 PM
J.Raymond's Avatar
'15 E400 Sedan '08 BMW 335i Coupe
It does look like a toe adjustment problem. There might a worn/broken suspension component that the alignment folks overlooked.
There is a link here to E Class issues with worn front thrust link bushings - similar premature inner edge tire wear - could be something to check for.
https://mbworld.org/forums/e-class-w...-problems.html
J.
Old 09-28-2014, 11:02 PM
ArcticE's Avatar
2014 G-550
Just got new tires and had the same type of wear on the inner part of the tire. I am not sure what caused it but I just got an alignment done with the new tires so I will see if they begin to wear the same way. Anybody else able to confirm what causes this?
Old 09-28-2014, 11:28 PM
bbirdwell's Avatar
'99 and '05 E55 AMG
Assume camber to be a negative 0.7 degrees (top of wheel versus bottom of wheel). If you have an 18" (457mm) wheel, use that as your baseline. Taking the tangent of the angle (tan[0.7degrees]=0.122) and multiply that by the diameter of the rim (0.122*457mm), the top of the wheel (not the tire) should be approximately 5 1/2mm "inboard" of the lower part of the wheel. If you have a 20" wheel, use 20"*25.4mm/"=508mm and multiply that by 0.122.
You need a vertical (and I mean vertical!) standard you can place next to the wheel. Measure from the standard to the bottom and then the top of the wheel. If the difference is ~5 1/2mm (with error bar equivalent to +/-0.5 degree) ie., the top of the wheel is tilted in 5 1/2mm more than the bottom of the wheel, it's not the camber. If it's not the camber, check the toe.
This is not rocket science. Seriously. Camber or toe. One or the other. It might be a bad bushing or ball joint or mis-adjusted tie-rod end but it is nothing but numbers.
Looking at these tires on the car it should be easy. If the tires are tilted in like a drunken Irishman (and I *like* drunken Irishmen!), it's the camber. If they are almost vertical, then I would bet dollars to donuts the tires are toed out significantly.
Search for "how to align a car using strings". It's a PITA but I use it to align my car and it works.
FWIW.
Old 09-29-2014, 09:56 AM
CEB
CEB's Avatar
1953 300 Adenauer, 1971 300 SEL 6.3, 1975 600, 1978 450 6.9
You need to quit going to "tyre places" and go to the MB dealer. Any repair will cost less than a new set of tyres every 10k miles.
You have a serious issue probably beyond a simple alignment. To get that kind of wear you must have suspension damage and it should be visible with the car at rest.
Old 10-11-2014, 07:34 PM
GLC300
LARKOTH - did you ever solve the riddle?
Old 09-25-2015, 08:00 PM
Bigbaldybloke's Avatar
mercedes e350 coupe
I have a similar problem on both sides of the car. There are also what look like rub marks on the suspension strut where the tyre has rubbed. I've been under the car on the ramps at Mercedes and there is about 4-5mm gap between the tyre and strut when stationary. Not sure how much the tyre will grow at speed. The garage don't have an explanation at present and I have refused to drive the car until I get a solution approved by Mercedes technical department. They have a possible mod, but I want a guarantee that this will fix it and that it is fully backed by Mercedes and I have something I can give my insurer to confirm the modification is fully approved by Mercedes.
Old 09-25-2015, 08:19 PM
mercedes e350 coupe
Just adding some photos of my e350 front struts. Mercedes deny these marks are caused by the tyres rubbing, but they line up exactly with the worn areas on the side of the tyres.
Rub mark on e350 front strut
Same marks on other side e350 strut
Old 09-25-2015, 08:28 PM
mercedes e350 coupe
Just for info, the tyres were 235x35 x 19" Yokohama. I've replaced them with the latest Continental Contisport 5 tyres. They had done 12000 miles and were about half worn across the main part of the tread.
Quick Reply: HELP! Front tyre inner edge dramatic wear???
