Rear speakers not working
E250 4Matic 2012
Hi,
I have a E250 4Matic Saloon, and I have just noticed that my rear speakers under the window are not working.
I was thinking about if there is a fuse I can check for?
And are those active speakers that are in there?
regards Zaiby
regards Zaiby
Have you checked the command screen and made sure fade is not set to front?
Received 4,417 Likes
'71 Pinto
If vehicle is equipped with premium sound (code 810) check f67 & f69 @ rear SAM if fine, try pulling in an attempt to reset. If this fails it would be best to have someone with MB diagnosis check for fault codes (warranty?) - quick/definitive answer.
Mybad55 (06-27-2017)
E250 4Matic 2012
"try pulling in an attempt to reset"
What do you mean by that and how should I do that?
There is no warranty on the speakers, only on the comand unit itself as it has been replaced recently before the warranty expired on car. But I didn't check before or after if all speakers were working or not.
'71 Pinto
Before pulling fuses, etc. have the shop that replaced COMAND unit revisit to assure system including all speakers are working properly.
E250 4Matic 2012
So that's why I want to see if I can do something myself before handing it over to them.
'71 Pinto
Check your PM.
