2014 E350 headrest removal question
2014 E350, 2001 320 SLK , 1997E 420 1987 560 SL
Hello does anyone know how to get the head rest off this car. I read that you need to remove the back by removing to the screws at the bottom of the back On my car there are no screws. I am trying to put sheepskins on the seat. Thanks Brian
Lexus LS 400, 2008 BMW 528i, 2014 e250 BlueTec
I am afraid that is not a simple as getting screws off! You'll probably have to take off back of the seat cover and get to the motor inside. Dealers will charge you about 150 to $200 for the job. That is my understanding. Check it out.
Headrest removal
Yes I know it's a hard job. I know what to do when I get in there. But I cannot figure out how to get the back of the seat cover off. In the past there were 2 screws on the bottom of the panel. But now they are not there that I can find. I think it might now snap out from the top and sliding it up.but I hate to do that without knowing for sure.
Received 4,417 Likes
'71 Pinto
Pull seat-back lining at the bottom far enough out to enable a screwdriver to lift the catch hooks see here http://workshop-manuals.com/mercedes...t-back_lining/
Brian
Photos of my head rest removal
Actually this was a very easy job to do. Please follow along with the pictures and you should have no problem at all.
Pull the bottom edge of the panel out about a half an inch and stick a screwdriver or better yet use a plastic panel tool to push up and release the clamp then do the other side. After both clips are released you gently pull the panel downward.
E
This is the back of the seat with the panel removed.
The circle area is where the head rest pole snapped into the power motor bracket.
With a gentle pull the head rest pole will unsnap, now do the other side now.
Now you must unplug the power cord to the head rest.
This is the head rest power cord un-snapped.
This is at the top of the seat. This is the plastic channel that the head rest pole goes down through the top of the seat. If you look very carefully you'll see a little clip that fits into the head rest pole to keep from pulling all the way out. You can see the notch circled on the next picture. Next use a small screwdriver and lift the clip out of the pole notch and the whole headrest will now come out. Note only only one pole has this. See next picture.
Here is the little notch that the previous pictures clip goes into.
And there is the head rest is easily removed. Reassembled by reversing this order. It was a very easy and simple job took about 10 minutes or less.
E
'71 Pinto
The vertical headrest adjustment is done by the motor under the headrest in the seatback while the power going thru the rod and into the actual headrest is for something else?
'71 Pinto
Neck-pro
Sheepskins installed
Hope you had the side cut outs for the airbag in your sheepskins. Otherwise, you could be in for a world of hurt if they blocked them.
https://mbworld.org/forums/e-class-w...ool-hiney.html
Side air bags
Brian
Side air bags
Brian
