2010 models and Automatic Car Washes
2010 E350 Luxury Sedan, Engine 272 (V6)
I checked with MBUSA Customer Care rep. who checked with a product specialist. On 2010 models, you can just turn climate control system off instead of activating the recirculation per Operator's Manual. This accomplishes same thing to protect the filtration system.
Problem with activating recirculation is that once car is turned off and then back on, recirculation is automatically deactivated. (More German engineering) Which is what happens when you leave the car and then an attendant comes to move it to the conveyor. Unless you leave it unattended and running.
Hopefully they know what they are talking about.
Instructions for attendant
I made the following instructions and leave them on steering wheel. In 20 pt. letters. My car is not keyless go.
AT START OF CONVEYOR
Engine Running;
Press and Hold brake pedal;
Shift to N;
Release the brake pedal;
Switch ignition off and leave key in.
DO NOT USE BRUSH ON CAR
Please leave this sheet in car.
Thank You!!!
Engine Running;
Shift to N;
Thank You!!!
This conversation was around a while ago.
In all my 7 cars over the years I never bother about shutting the HVAC system off or into recirc mode. Never had an issue either.
Good
Perhaps it is an overly defensive disclaimer by MB just in case something happens?
One way to treat odours in your HVAC system is to put about 2 tablespoons of hydrogen peroxide in about 1-2 cups of water in a spray bottle.
Spray this down the intakes where outside air enters the system with the car in both heating and cooling modes. Hydrogen Peroxide will kill off the bugs that cause the odours.
