Strange noise after car being parked
Hello everyone,
I parked my car this afternoon after a short trip. Came back to pick up my phone -forgot it inside the car- and I heard this strange noise coming from under the hood. Please have a listen.
So the car being parked in the garage, no keys and alarm is off.
Would appreciate any thoughts of what could that be.
Thank you all
Thank you all
Having trouble hearing the fan from the file you posted. Have you identified the location of the sound.
Possible locations from past fan noise threads that I recall include:
1. radiator fan - front of car
2. HVAC fan (in 'drying' mode) - inside plastic cowl near bottom of windshield passenger side
3. LED headlamp cooling fans - only on applicable models with these lights.
Thank you for the info
It was hard to identify the location of the noise. However, I don't believe it is a fan noise as it was not constant. Since you mentioned the possible three locations I will look these locations over and check if the noise coming from one of them.
Received 1,616 Likes
2014 E550-sold 😩
That is a strange metal sound that I have never heard before. Sounds like a woodpecker trapped inside the engine compartment drilling on a metal pipe. Bizarre
These E class cars are noisy, but that is a first for me.
Hello everyone,
Thank you all
Thank you all
Really strange noise and the two intervals between the three noises are very much the same 15-16 seconds...
Does this continue for long time after you turn off the car? if it stops and the interval gets bigger between the sounds before it stops then could it be cause by the engine coolant pressurizing and pushing thru the pressure valve at the radiator cap?
When the engine stops the coolant stops circulating and heats up inside the engine channels to a point it can start boiling. This would cause excessive pressure in the system and perhaps cause steam to escape thru the pressure valve to the ganister.
The Audi Q7 I had was equipped with an electric circulation pump that kept running and circulating the engine coolant after engine shut-off until the temperature was below some point that does not make the system overly pressurize. Wish my MB had that too...
2014 E550-sold 😩
I have had two Airmatic MB's and have never heard a sound like that, but that sound does have a "sucking through a straw" kind of tone to it. You may be on to something.
Arrie. The noise did really sound like what you descried "steam to escape thru the pressure valve". Yes the interval was getting bigger -i waited in the garage for around 15 minutes and at some point i though it was happening with over a minute interval- I checked the car few hours later and it was quiet.
Yes the car has Airmatic
I did not drive the car the past two days, but will keep you all posted.
Thank you all for your replies
Any updates from the OP?
I have a 2014 E350 (so it is not related to airmatic) and noticed the same exact sound coming from somewhere in the engine bay when the car is off after a drive. It only happens after some drives. I don't think it has happened since the car was new. Somewhat periodic in nature. Sometimes it stops after a few minutes, sometimes it will take an hour or more to stop.
I have no updates
I really have no updates and I kinda forgot about that noise. But, it is exactly as you described it (Somewhat periodic in nature) and it does not happen after each drive, it is really intermittent.
Hey, I drive a 2010 E550 with airmatic. I just heard this sound from my car too. It comes from the lower half of the engine. It was my first time hearing this sound since I got the car in February. It seems to come on 15- 30 minutes after switching the car off. A few hours later i checked up on the car and the sound was gone. Just wondering if anyone has an update of what is going on?
2015 E 250, 1999 BMW M Roadster, 1939 International Harvester, 2023 GLC
do you have the lighting pkg? These have a cooling fan that runs for a bit after you turn off the car. Mostly in warm weather
Im not sure if i did. I have the hockey stick DRL, with the Xenon beams up front? But the weather outside is like -20c I didn't hear it in the summer?
