Commonalities between the M278 and M157 engines?
Old 04-15-2016, 10:44 PM
iGeorge's Avatar
'12 E550 4M, '14 ML5504M
I'm just curious if there are shared or common parts between the bi turbo engines in the E550 and the E63. Any thoughts?
Old 04-15-2016, 11:11 PM
cocobeex's Avatar
2014 E550 4MATIC TUNED - Turbo Upgraded Stage 3
I also want to know toooooo
Old 04-15-2016, 11:32 PM
kustom2k1's Avatar
03SL55
http://australiancar.reviews/mercede..._M157_M278.php
Old 04-16-2016, 09:14 AM
gardevski's Avatar
cls63 amg pp 700hp, ml63 amg w166 700hp, cls550 4matic 720hp
Both engines are sharing most of the parts. Iám trying to fit m157 turbos on m278 (cls500) so the exhaust manifolds are same except the M157 turbochargers feature water cooling in addition to the oil cooling. the m278 engine with some mods is currenty at 500whp but after 5000rpm turbos are out of steam..
The following 2 users liked this post by gardevski:
cls5504matic (08-30-2020), GreyEminencE550 (03-16-2019)
Old 04-16-2016, 07:43 PM
cocobeex's Avatar
what about transmission ? can it hold that much power ?
I am think of Bulletproof transmission from Weistec or Renntech.
Old 04-17-2016, 03:24 AM
gardevski's Avatar
My car currenty run 1100nm to the engine and not a single issue with the gearbox or drivetrain (special intake mod to lift the K&N airfilters, AMG 63S IC pump and additional radiator, Alpina b7 spark plugs, catless downpipe, stage 2 custom software). Mercedes is limiting the torque electronically on the lower gears. We are expecting to go ~700hp on m278 with the right setup and exhaust (the 550 series has 60mm exhaust pipe diameter compared to 70mm for the 63 AMG) including M157 turbochargers.
Old 04-18-2016, 06:35 PM
BlownS4's Avatar
2015 E63 - Current, 2012 E550 - Current, 2019 Audi Q7 3.0T - current
Holy crap 800 ft lb of torque??? are you daily driving it or is it a weekend car/toy? so what exhaust are you running and is it from the downpipes back?
Old 04-18-2016, 06:39 PM
cocobeex's Avatar
I'm very interested to see your dyno and track timing!!!!!
Old 04-18-2016, 07:15 PM
BlownS4's Avatar
would love some more details on the mods as well. Like the intake mod and I'm assuming you have an E63 S IC pump and radiator. I wonder if your setup is similar to the cooling setup AMS is running for our cars
Old 04-19-2016, 08:08 AM
gardevski's Avatar
Hello, Here you can see dyno run
Facebook Post
0-100km/h 3.8-4sec (with brand new continental 5p and light weight wheels) 100-200km/h 8.3-8.5sec (it's good for 4matic) stock 100-200 was 12.2-12.5
Also the car has splited intercooler water from the main engine water
If you need any other info let me know. The car ECU is calibrated for 100 octane EU spec fuel
Old 04-19-2016, 01:30 PM
blegthbloo's Avatar
2013 E550 4Matic
^^^ You should start a build thread in here. I'm sure a lot more people than have posted already would want to know more about your mods. It would certainly detract from the mundane "why doesn't this work" or "what does this button do" question threads that are common in the W212 threads lol
thelenswap (11-28-2020)
Old 04-20-2016, 09:14 AM
nicobaires's Avatar
13' E550, 14' Ram, 99' E39 wagon
build thread please!!!
Old 04-21-2016, 10:14 AM
gardevski's Avatar
When i have more time will make it. Now waiting for the M157 turbos, some parts needed for the turbo swap including bigger exhaust (70mm pipe diameter, cooling lines etc..) . When all is complete will let you know what's needed to install bigger turbos on our cars
Old 04-21-2016, 03:20 PM
BlownS4's Avatar
Good lord I love this build!!! you will surprise the **** out of E63S now I'm hoping with the turbo upgrades you will blow the doors off of a tuned 63!!
Old 04-23-2016, 03:33 AM
mjec515's Avatar
2014 e550 4matic
BUILD THREAD PLEASE!!!
I WANT TO SEE MORE OF THIS BEAST!!!!
Old 05-15-2016, 04:35 PM
gardevski's Avatar
Hi Guys,
I'am about to build the thread for all my mods here
Just receive the M157 turbochargers and all other parts needed including the 3 inch turbo-back downpipes to muffler exhaust system. Target 700-750hp from m278 engine Hope i can help others with the upgrades. P.s the other day i had track session with 530hp GTR and it doesen't feel any faster than my cls..
Old 05-15-2016, 09:16 PM
BlownS4's Avatar
Hi Guys,
YES!! finally someone who is not afraid to go all out on a 550 vs being told to just buy a 63. I'm super interested in the cooling and part as well because I keep hearing that these cars suffer from heat soak after a few dyno pulls and on the track. You rock gardevski! please don't kill us for bombarding you with questions!
Old 05-15-2016, 10:18 PM
PeterUbers's Avatar
Received 1,881 Likes on 1,319 Posts
2014 E63S; AMS 100 octane ecu tune; edok tcu tune; BB intakes; dyno tuned
That's great he wants to build up his 550 but buying a used 63 with a warranty makes more sense
Should be a good thread ... Love the line about the 7gtronic stock handling the 800lb-ft LOL
Old 05-16-2016, 02:33 AM
T.H.Carrera's Avatar
2012 w221
it is true, it will handle it ONCE, after that you will need another
Old 05-16-2016, 06:12 AM
cocobeex's Avatar
Hi Guys,
WOW!! Can't wait to see these goodies installed and dyno'ed.
Any 1/4 mile records ?
Old 05-16-2016, 07:41 AM
gardevski's Avatar
Don't worry about the gearbox. The current CLS550 and E550 have 7g tronic plus. I have 63 amg s-class with m156 engine that has 1/2 the torque of my 550 and the gerbox is not much stronger. CLS550 first two shifts has torque limiter to prevent damages (even the 63 amg MCT box will not hold full torque on the first two gears of the line)
If i go for 63 it will be from the next generation cls or e63 amg. No need to buy car that will be hard to sell after the new models come in production in the next 1-2 years.
Old 05-16-2016, 06:31 PM
cocobeex's Avatar
Here is the specs of 7g tronic specs
http://www.europeantransmissions.com...edes-trani.PDF
Old 06-27-2016, 01:59 PM
cadeshawinters's Avatar
02 c240
EGR VALVE?
My Mercedes c240 will not start. Check engine light came on months ago got it checked out and they said it's the EGR valve. When it shut off it said battery/alternator. When I try and start it it sounds like it wants to start but when I go to give it has nothing happens. Would EGR valve cause this? Alternator and battery seem okay. PLEASE NO RUDE COMMENTS JUST LOOKING FOR HELP 2002 Mercedes C240
Quick Reply: Commonalities between the M278 and M157 engines?
