Things sure are different- DIY then vs now
Got my 1st car when I was in college- a 1973 Pontiac Grand Prix. I tried to do as much myself on the car as I could. Did tune ups (2 of the plugs were a bear to access). After that I had a Toyota Celica. Did tune ups, oil changes, brake pads and shoes, ripped out the stock Fujitsu audio system, and put in a Blaupunkt head unit, Alpine speakers, Clarion amp. Then came a couple of Nissans (my first new cars) and I was chicken to do stuff because the cars were under warranty but once warranties lapsed, I did oil changes and brake pads. I also use to rotate tires.
These days I have no idea what ever happened to my ramps, and I think the most adventurous I am in the DIY realm are wiper blades, engine air filter and cabin air filter.
Forget oil- now you need to dispose of the oil properly (of course I did that also in the 7o's and 80's :-). I did a set of plugs on a Honda a couple years back, but now with aluminum heads I'm afraid of stripping a thread. So on my w212, I think it's going to be blades and air filters and washer fluid but the owners manual makes me wonder whether the washer fluid I've been using for 40 years will cause my Benz to implode. Truth be told, I no longer have the time or inclination to do the other stuff.
I guess that's part of the difference between being a teen and being as my oldest son is fond of saying, an old dude.
Received 1,616 Likes
2014 E550-sold 😩
Right there with you buddy. I still manage to have an older car around that I can tear into, so I don't lose complete touch. I just sold my '69 Mach 1 after finishing everything it needed. Time to get another.
So far I've done all the filters and the oil change on my 2010. Also bled the brakes and did all the inspections on the last B service. The car is out of warranty, but even so, that isnt the deciding factor. I like to do this kind of work myself and know that it is done right. It also keeps me in tune with how it is running and makes it easier to stay ahead of problems.
I think the OP has bought into the myth that these cars are so complex that mere mortal shade-tree mechanics cant even touch them. Some things I wont do, but routine maintenance isn't that bad.
I used to be like you and did as much as I could. Of course cars back then didn't have computers you had to plug into to read codes or release electric parking brakes etc.
But now that I'm older (not really that old, 40's), and have a bad back and restricted motion due to bad back, I can't really do much anymore. Getting down under the car is easy, getting back up is a whole different thing.
Of course our incomes have also risen significantly, so spending a few hundred once a year to take the car to the dealer isn't as big an impact as it used to be.
When I was 20, spending even a few dollars more to bring the car to an oil change place was unthinkable. Now as far as oil changes are concerned I have neither the time or inclination. Yet I know I can do an oil change (can't be any more difficult that building the tubed hifi equipment I have belt over the last few years!)
Yes, somethings are more complex and you need a computer to diagnose. But my time has value and thankfully I earn more than I did 30 or 40 years ago.
Are you factoring in the time + gas cost to get to the shop, talk to the advisor, etc etc?
With an oil extractor the oil change can be finished in less than 30 minutes,
and the oil filters are now on top of the engine so one does not even have to get under the car.
Just something to think about.
I do all of my own work, even heavy/technical stuff. Fuel injectors & steering box on my Ford, oil changes, transmission filters & oils, etc. Restoring my 1970 Torino Cobra too. Nothing really scares me off...but I'm 39 years old, so eventually I might get bored.
On my E350 I bought the oil extractor pump on Amazon and don't get under it for oil changes. My wife just bought a 2016 Escalade and I'm anxious to change its oil...2300 miles so far. I'm a nerd like that.
I love working on cars, but I totally get why some people don't, and why others used to enjoy it but prefer to pay someone to do it for them now.
Yes, I am. I still need to bring the spent oil somewhere.
The reason I do most of my own work is to save money and make sure it gets done right. An "A" service is probably about 2-300 bucks at the dealer and most of it is changing the oil. If you buy the oil yourself (Mobil 1 at wallyworld) its about 50 bucks. Add in the correct filter cartridge for another ten. So you are at 60 bucks plus the time it takes , maybe an hour at most to do the oil change and you can run through the checklist and sign that off too. Eventually you need to dispose of the oil, and that is pretty much any parts store nearby as a service to their customers. Is it easier to just drop it off and pick up a loaner? Sure, and as long as you are happy paying the difference, more power to ya.
But your original post talks about the car imploding if you use the wrong washer fluid, and that just isn't so. DIY maintenance is very doable on these cars if you are inclined and know what you are doing. I don't think you save time unless you have the dealer pick up the car and return it serviced, but again, you pay for that one way or another.
I can't agree more with you guys. I don't want anyone touching my car if I can do it myself and know what's going on with it. I'm also a cheap-***, so it works out. I can't imagine paying a dealer $300 for an oil change. They just take it in the back and let some high school drop-out do it. If you think some master mechanic is changing your oil back there, no way.
MB are not any more complicated than any other new vehicle. They all have basically the same parts, some are just more expensive than others. Specs on fluids and other things can be found easily in the manuals or forums.
W212 are still too new and expensive for a lot of DIY'ers, but good info will fill in here as they get older and passed on.
Received 1,886 Likes
2014 E63S; AMS 100 octane ecu tune; edok tcu tune; BB intakes; dyno tuned
- their liability if something is done wrong
- time and effort is entirely theirs
- car wash
- my hands are my livelihood... If I get injured I can't work ... Someone else can take that risk on... Not saying it's a lot but things happen
- I hate disposing of oil
2013 E350 4Matic
Here or any other luxury brand forum motto is , if it isnt expensive then it must be crap. Its completely fine if someone wants to spend their $$$ and not touch anything on the car, but please stop posting crap about how complicated the services are if you have not turned your own wrench to do it.
Not saying that the high school dropout is a genius, and my dealer wants $100 for an oil change, still expensive, but there is a bit more to taking the car to have the dealer do the oil -
- car wash
- car wash
most of the DIY stuff I've done I either end up hurting myself or breaking something. Got scalded a couple times years and years ago changing my own oil and other car maintenance from under the car. So I stick to the simpler stuff like air filters - but that hasn't stopped me from over-torquing or stripping the occasional screw. Just clumsy I guess. If I would have had the equipment to pump oil out from above, I might have kept at it.
Now I mostly fix stuff that interests me like appliances and computers that require basic tools.
YMMV!
