Do these fit?
Do these fit?
Wanted to know if these specs will look good on a 2014 E350 sedan.
Bolt pattern: 5X112
Offset: 35
Size: 20 X 8.5 ET35, All around
Front tires 255/35/20
Rear Tires 255/30/20
Thanks.
Bolt pattern: 5X112
Offset: 35
Thanks.
OP probably means 255/30-20 all around, in which case yes they fit with no issues while on 8.5" wide et35 wheels. (Of course there's zero chance of fitting 255/35-20 upfront - wheel won't even rotate, nor will it fit the rear without rubbing).
I noticed the different tire aspect ratios you listed. The rears would be shorter than the fronts. If you are actually using the same size all around, then it would look OK. No comment on fitment as I have no idea.
