Reset W212 air conditioner
Any one know how to reset W212 air conditioner? I try to press the recycle and defrost button simultaneously, but the LED does not flash as said.
Not familiar with the reset process for AC. Maybe just pull the battery connection? What's the issue you are trying to correct?
THread resurrection. My aircon is suddenly suffering from a delayed start. When firing up the car, fan blows full speed but no cold air at all. Then after a few minutes, a sudden blast of cold air as if the compressor if finally running (not a gradual cooling of the air flow). Is there a reset procedure for W212?
Received 1,729 Likes
1922 Ford Model T / no OBD
What would be "reset" for AC?
Those systems operate with at least 8 sensors, so when you have a trouble, you better do sensors reading as crystal ball leaves big error margin .
