Sign in using an external account
| G-Class (W460, W461, W463) 1980-Present: 290 GD, 290 GDT, 300 GD, 350 GD, 500 GE, G 250, G 300, G 300 DT, G 320, G 500, G55 AMG |
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 | ||
G55 tires size replacement
#2 |
Drives: 2009 CL65, 2011 G55, '97 LandCruiser 80 (E Europe)
There should be no issue replacing the stock 285/55R18 tires with 275/60R18 as the overall diameter increases by .65" so only a .323" difference going into the wheel well at full flex and little difference to your actual and shown mph. That said, it really would be wise to jack up a front wheel and then a rear wheel and check how tight the clearance is as you don't want to see a wheel come through your fender.
Also, the width is only 1 cam apart so there will be no issue with the tire being overly stretched over the rim even though the AMG rim is, iirc, 9.5" wide compared to the 500/550s 7.5 rim. Now, take all of this with a grain of salt. The sizing info above is accurate but I myself run 285/55R18 (I replaced the 2011 19s at purchase for no cost for the pre-2010 AMG 18s to gain more sidewall for both ride quality and off roading). Long story short; personally I'd stick with the stock sizing unless your lifting it. Last edited by ramzank; 09-23-2011 at 12:01 PM. |
#3 | |
Drives: G350 Bluetec
Quote:
#4 |
Drives: 2013 G 63 AMG
I replaced the Yokohama AVS/ST with their Advan S/T on my previous G55 and found them to be a quieter tire with better braking distance and less susceptibility to flat spots. Also, they handled some off-road driving decently.
__________________
![]() 2013 Mercedes-Benz G 63 AMG Designo Platinum Magno (matte), two-tone Designo Classic Red/Black leather, AMG Exclusive Interior, AMG matte black painted 20" wheels. 2013 Mercedes-Benz SL 350 (wife) Iridium silver metallic, two-tone red & black leather interior, black ash wood trim, 19" multi-spoke wheels, glass panorama roof, active park assist, keyless-go. 2006 Aston Martin V8 Vantage Previous G-Wagens 1991 300GE Brabus 3.6, 2002 G500, 2004 G55 AMG, 2010 G55 AMG "Edition '79" |
#5 |
Did you find them in thhe same size? The only thing I can find in 285/55/18 is the same OEM tires. Another tire company suggested 265/60/18
#6 |
I had to special order them in that size...took about 6 weeks. I'm in Dubai, not the US. Perhaps they don't make them in that size any more? Try contacting Yokohama in the US directly and check if that size can be ordered...worth the effort.
__________________
#7 |
Drives: CL600
for winter purposes, will stock 18" g500 rims fit a 2005 g55 and clear the brakes? need to get rid of the yoko avs before the snow hits. thanks.
__________________
2006 CL600 Iridium Silver/Black Speedriven: ECU, TCU, Turbo Back exhaust -V2 lowering module -Kleeman TS6 w/PS2 -Escort 9500ci 2005 G55K Grand Edition #416 |
#8 |
There should be a tire size calculator on tire rack. If not, try 1010tire.com, a Canadian site, that has a flexible tire calculator and lists the brands available in winter performance and stud less winter tires including some that tire rack doesn't stock but are available and good choices. I like the Canadian reviews because they have on average extreme conditions. I use winter performance on my CL and stud less on my G for obvious reasons. In any case get a snowflake rated tire because the rubber is for cold. The regs in the states say the installer can go down one speed rating say H from V+. Dont let people fool you. I know many independent retailers refuse to put any wheel but a genuine AMG wheel on my CL so the tire thing is easy. If you stick with 18" you can use a narrower tire for snow and ice conditions, say from the stock 55 to a 60/65 as long as the wheel width range is recommended. The spec table for each tire Should tell you the actual tire's rim dimensions, remember they are flexible! Finally I went a slightly narrower stud less tire that had a bit greater diameter and had Comand adjusted through Service Mode to correct for the change. This is important because it not only interfaces with the Speedo but I think ESP and so on.
There are plenty Last edited by grane; 01-05-2012 at 10:42 AM. Reason: 18, 19, who knows? |
#9 | |
Quote:
Where are wheel works located? Their calculator by model is lame and cya. Find an indie installer. Last edited by grane; 01-04-2012 at 09:09 AM. |
#10 |
Anyone heard or Maxxis Marauder tires?
There are 2 options of tires I found for the g55 wheels. Pirelli scorpions or the Maxxis Marauders. Has anyone replaced their tires with any of these 2 brands?
#11 |
Drives: Mercedes G55 AMG
I bought set of michelin tires like those on 09+, but with the exact size of 05.
__________________
Black G55 AMG Kompressor w/ Designo Tan Leather / Bi-Xenon / New 2009 Grill / New 2008 Tail lights / extended AUX/ 20% tint / Smoked Side Markers |
#12 |
Drives: TT
so what did you go with on the 18in wheels, 275/60, 265/60 ? tire brand? I would like to find a replacement i can use in the snow (san francisco to tahoe) thanks!
#13 |
Drives: 2010 G55, 2010 C250, Volvo S40 T5, Pajero, Passat, 1995 SL500
OEM 2010 is 275!
| Tags |
| 2009, 2010, 2011, 28555r18, g55, oem, prices, rim, rims, size, specs, tire, tires, wheels, yokohama |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
