Go Back   MBWorld.org Forums > Mercedes-Benz SUVs, Trucks, Vans, Diesels, Other > G-Class (W460, W461, W463)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors
Welcome to MBWorld.org Forums
G-Class (W460, W461, W463) 1980-Present: 290 GD, 290 GDT, 300 GD, 350 GD, 500 GE, G 250, G 300, G 300 DT, G 320, G 500, G55 AMG
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 03-26-2012, 06:55 AM   #1
Drives: W204
improve road handling and brake system
I use the G class as daily car and noticed the G is a bit soft with the suspension. Surprisely the G350 uses AMG shock ?!?! but somehow it still feel soft when turning through the corner; sepcially when u try to brake and turn at the same time which causes the tire lose traction
1. want to keep the same height
2. don't want to get the BRABUS air-suspension(ride control); too dear
What option should i go ?
1. upgrade to 20" wheel ?
2. upgrade Brembo Big Brake (380mm) ?
3. BRABUS sports dampers reinforced ?
many thanks.
To remove this ad, register today or login if you already are registered!
milsons200 is offline   Reply With Quote
Old 03-26-2012, 08:59 AM   #2
Drives: G350 Bluetec
1. Go to a thicker sway bar in rear at least.
2. Install HD Bilsteins. Check to make sure BS makes them for this model. As I recall they do.
3. Put a bit more air in your rear tires.
Braking and turning may cause loss of traction in any case. If it is AWD try turning in smartly and giving it gas. I am told this is recommended for understeering cars. It works in my G500. Practice in a big open parking lot without obstructions until you get the knack of it for safety sake.
GLuck!
grane is offline   Reply With Quote
Old 03-27-2012, 08:11 AM   #3
Drives: W204
Thanks !
GLuck!
Tags
bigger, brake, car, changing, g250, handling, improve, mercedes, shocks, w204, w463
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright © 2001-2012 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
SEO by vBSEO 3.5.2
