HELP SUNROOF WONT CLOSE AND ITS GOING TO RAIN!
I took the bulb out of the dome light while it was on because i was trying to seal the antenna hole and when i put it back, none of the light will come on in the center dome area and sunroof is stuck in the open position. If it possible i just blew a fuse? Someone help, the car is outside and its going to rain tomorrow!
I'm guessing a fuse because everything was fine until I took out bulb and replaced it. The center dome buttons do not work and the lights for the sun visor mirrors don't come one. I need to locate the fuse box and check.
