G55 2010 issue need help
hi
how are you MB owners need your help and experinece with my problem
i have G55 2010
some time while am driving its just shut off on very low speed
it happens almost onec evry 2 month
i have been leasen for my suggestions about the problem
already changed the oil,filter for the engin also the spark plug and fuel filter used MB parts
so please if any one face the same problem
good to mintion that i done computer check for the car after the shut off and there is no errors
regards
i have G55 2010
regards
My 2014 did that and dealer replaced fuel pump module with a new fuel pump. So far so good. Hope this helps.
Does it sometimes take longer to start? That can indicate a problem with the crankshaft position sensor. Its probably the easiest to replace in the G with the M113 engines, and I've been told it is a usual problem.
