shaking while driving
Old 12-19-2015, 05:27 PM
victordakhteh's Avatar
2003 G55 AMG
Exclamation shaking while driving
hey there fellow G's
So I've had this issue for a while and have read on it, its the shaking of the car that happens between 55-65mph. Now people say that it is the steering damper. However this is how I consider my situation to be different, because I do get the shaking between 55-65mph and sometimes it can pretty turbulent, but this only takes place within lets say the first two miles or less of driving. And the turbulence part of it hits the most even when I am steering at a slight angle to merge on the highway since my trips always land me on the highway. Now do you also feel that this may be in fact the steering damper as well? I spoke with my service adviser and he's thinking tires, but I feel like that might be a load of crap or else the shaking wouldn't stop after two or less miles you know?
any thoughts would be great, thanks
Old 12-20-2015, 08:28 AM
1Cigarette's Avatar
2018 C43 Cabrio , 2012 G550 Edition Select ,2010 GL 550(sold) , 2009 C350 , 2004 C240
I agree with your service advisor . Tires .
Old 12-20-2015, 05:19 PM
2003 G55 AMG
My tires still have tread for a few thousand miles though, doesn't make sense to be tires, I feel like if it were my tires the shaking wouldn't stop after a mile or two, shouldn't it continue to shake if it were the tires?
Old 12-21-2015, 02:07 AM
kotton's Avatar
2011 E550 , 2006 G500
Death wobble usually stems from worn out joints. I would take a look at your drag link and tie rod joints to see what they look like, as well as the bushings in the control arms. The steering damper usually masks these types of problems until they become very apparent.
Old 12-21-2015, 09:31 AM
SteveE400's Avatar
2015 E400 and 2015 GLK350
Could it be simply tires having "morning sickness." New or old tires sometimes develop minor flat spots after sitting overnight. The fact that the wobble seems to disappear after a few minutes of driving could mean just this. Driving on the tires heats them up and the flat spots revert to their normal round shape.
I've had some tires that sounded like the old "Flintstones Car" routine -- flap,flap, flap as they rolled in the morning, but after a few miles they were fine.
Old 12-21-2015, 01:53 PM
aerG500's Avatar
I dealt with the SAME EXACT situation... and went thru over $12K worth of experimental repairs
New Drag Links
New Trailing Arm Bushings (twice. once with factory and second time with Poly bushings)
New Wheel Bearings
New New Control Arm Bushings
New Panhard Bushings
New Panhard Rod (after bushings alone didn't do the job)
New Shocks
New Springs
New wheels
New Tires
New Steering Damper (Twice, once with factory part and then with Bilstein gas shock upgrade)
New Transfer Case Mounts
Laser Alignment 3 times thru 2 different shops
Road Force balance 4 times thru 3 different shops
Re-tighten wheel bearings
New Transmission Mounts
STILL DEALING WITH IT. I have spent HOURS on the phone with MB USA to no avail... have had TWO Different factory dealers and one independent (ex factory master tech) do all the above work....
STILL DEALING WITH IT AND IT DRIVES ME FRICKING NUTS.
Let me know what you come up with
Quick Reply: shaking while driving
