turning off Differential Lock Control
09 G55, 07 M6 Conv, 01 Porsche Turbo
Can someone tell me how to turn off the middle Differential Lock. I put it on the red lit ; pushed bottom of rocker red went out but bottom amber lit.
How to get light on switch to go out completely?
2013 G 63 AMG
The G-Class uses vacuum hydraulic differential locks, but in order for the locks to engage or release, there needs to be some slippage. First of all, never lock the diffs on tarmac as this puts too much strain on them. In order for them to lock, there has to be some slippage, so try driving forward a little and turn from side to side...same is true for releasing them. Even if you press the switch and the red light goes off, the amber one only goes off once the lock has actually disengaged.
2004 Land Cruiser, 2009 G55, 2013 C63 Black Series
for how long did it stay locked?
if you drive forward a little and do a couple of turns like jimmyg said, it should disengage. Sometimes, reversing would help.
10 speed bicycle
Thanks guys, all set, the correct operation leaves you with the feeling like something isn't right because it takes some slippage like Jimmyg and others indicate for the amber light and the ABS indicator and others to go out.
Took it off road in the snow as we had a blizzard yesterday that delivered about 24" of snow...a lot of fun, I think its impossible to get the G stuck after that experience.....for everyone who was wondering about snow tires I have to tell you that imo the stock tires are really quite competent.
Boston was hit hard with snow, yes. I heard.
ps: I am sure all season stock tires do just fine in the snow.
1 Post
2010 G55, 2010 C250, Volvo S40 T5, Pajero, Passat, 1995 SL500
Took her offroading yesterday and today in Jebel Ali... Why does diff lock II take a good 0.5-1 min for its top light to go on? Was moving around a bit to help it... !!
2013 G 63 AMG
Moving around helps...but even then the lock may not fully engage until there's some slippage. Also, if the they are not used often/ever, sometimes it takes time for them to engage. Neither engaging or disengaging will be instantaneous.
1 Post
On one youtube video, right before the MB offroad trainer took the 63 up on Iron Schokel, it took 3.5 sec to engage the rear diff while stationary.
BTW, saw a G79 yesterday (gorgeous) on my way to JA driven by two Dubai Policewomen!
1 Post
Yes, Sir Had "G79" on the back, where u'd normally have "G55".. Both my son and I saw it! Two policewomen at the helm!
Btw, having the diffs (and brakes) checked at Gargash next Sunday, just to make sure they're alright.
Hi,
who know how to engage diff locks. sep by step..
1. Start engine gear in N engage LOW.
2. for lock 1.mid2.aft.3 frwd gear should be in N or in D????
According manula N only for Low gear , for other lock i did find anything.
G55 2011
G55 2011
