Sign in using an external account
| G55 AMG (W463) Discuss the G55 AMG. |
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 | ||
Drives: G500
#2 |
Drives: '10 G55, Challenge Stradale, GT3
It could be several things but I would start with the least expensive and easiest fix. Balance your tires. I would also ask the tech to check the condition of each rim especially the fronts for a possible bent rim.
#3 |
Drives: Arctic White 09 G55, 040 Black 09 C63
i am having the same problem in my g55
#4 |
Drives: G500
Thx AGR. Will keep you posted.
#5 |
My experience is that it has to do with the actual tires. I'm on my third G-Wagen (one G-500, two G-55), they all did it. All had Yokohama tires. As it gets colder, they develop a sort of flat spot while standing. The vibration/shaking went away after a couple of miles. Last month I replaced the Yokohamas with the Pirelli Scorpions. Same shaking, still going away after a few minutes. The installer checked, rotated, checked the rims. Everything is perfect. It's the rubber.
#6 |
Drives: 88-300CE TWIN TURBO, 99-C43, 05-G55K, 71-280SL, 94-E320 CAB, 08 CLK63 BLACK SERIES
Tires are like bricks when cold, but the main problem typically is the steering damper..
__________________
TURBOTECHNICS TWIN TURBO M103 300CE WIDEBODY ![]() 1971 280SL 1988 300CE TT 1994 E320 CABRIOLET 1999 C43 AMG 2005 G55K AMG 2008 CLK63 BLACK SERIES AMG |
#7 |
My truck is having the same issue now that it is getting colder. I have P Scorpions on Brabus wheels which have been balanced and aligned. They said to "overinflate" the tire a bit to reduce the tendency of flat spots. If the issue goes away after a few miles, then the flat spot from sitting is the likely cause.
#8 |
#9 |
In my 2003 I replaced the damper twice.
My 2005 doesn't seem to have the same problem. Ed A.
__________________
| Tags |
| 2003, 50, 60, damper, g500, g55, mph, shakes, shaky, shimmies, steering, updated, vibration, w463, wagen |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
