Sign in using an external account
| G55 AMG (W463) Discuss the G55 AMG. |
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 | ||
__________________
2004 G55 AMG - Brilliant Silver w/ Black |
#2 | |
Drives: 300ce
Quote:
.........down sizing the fender flares may affect resale value it doesn't matter. It's your car, fix it up as you prefer. .......since you have the NA G55, one option you might consider is to sell her and get a G500. You won't loose too much power and you'll have the "classic" G-wagon look you prefer and you can and you can pocket the difference in price between the higher priced G55 and the G500. Ted |
#3 |
Drives: 2013 G 63 AMG
Why are you putting narrower wheels on?
__________________
![]() 2013 Mercedes-Benz G 63 AMG Designo Platinum Magno (matte), two-tone Designo Classic Red/Black leather, AMG Exclusive Interior, AMG matte black painted 20" wheels. 2013 Mercedes-Benz SL 350 (wife) Iridium silver metallic, two-tone red & black leather interior, black ash wood trim, 19" multi-spoke wheels, glass panorama roof, active park assist, keyless-go. 2006 Aston Martin V8 Vantage Previous G-Wagens 1991 300GE Brabus 3.6, 2002 G500, 2004 G55 AMG, 2010 G55 AMG "Edition '79" |
#4 |
Ted: Makes sense. I like the 55 over the 500 for the nicer leather, the great exhaust note (love the side exhaust actually) the slightly beefier engine, etc. Truth be told I had been looking for 500 all along, but after 6 years of searching for the perfect vehicle, this one presented itself and I couldn't pass it up.
Jimmy: I've fallen in love with a set of rims that only come in a 9" width for our offset. Look great on a 500, not so much on a 55. I don't actually care for the stock 18s, and a set HREs is out of my budget for now. Just trying to think through different sensible options. Andrei
__________________
#5 | |
Drives: 2003 Kleemann G55k
Quote:
__________________
The Stable: 2003 MB G55...k 2003 DINAN E39 M5 ![]() 2012 Indy Fab Ti FLW 2011 Indy Fab Ti FLW MTB 29er 2007 Indy Fab Steel Deluxe SS 29er |
#6 |
BonitaBeast: You bring up an excellent suggestion. I've attempted to do my due diligence in researching spacers for our vehicles...with mixed results. Some seem to hint it works, some hint that its not a good idea.
I tried to use spacers on my old c230k with Brabus 19s and wheel vibration was a pretty significant issue. Has anyone successfully run them on a G and have a recommendation? I was looking at the H&R ones... Thanks in advance to everyone for the continued help. Andrei
__________________
#7 |
I believe JimmyG is using 30mm spacers with success, based on his sig.
From experience With H&R spacers, 10mm and wider have a built in hubcentric lip which allows perfect centering of the rim on the hub. I use a 10mm H&R spacer on one of my other rides and have no vibrations all the way up to 300km/h (~185mph). Anything less than 10mm do not have that built in lip which may cause uncentered mounting of the rim onto the hub. 3mm would be the max I would do without the lip since 3mm is thin enough that the hub lip from the actual wheel hub of the car would still protrude past the spacer to allow perfect centering of the rim to the hub. Some have mounted up to a 5mm spacer with no lip, but I wouldn't take that chance. I hope that makes sense.
__________________
#8 |
Yup, I have 30mm H&R spacers. I've also seen people use 45mm, or 2x30mm which is crazy. The majority of G55's in Dubai run with 30mm+ spacers.
__________________
#9 |
Nice! Thank you so much BonitaBeast and JimmyG. Now that I know the H&R 30mm spacers work well, that's one less worry I have with the new rims. Once I get them on and installed, I'll post my feedback on how they worked out, just so we have another documented user with the setup.
Thanks again to all.
__________________
| Tags |
| 463, amg, compared, difference, exhaust, fender, fenders, flakes, flare, flares, g500, g55, mercedes, natrow, w463, wider |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
