G55 AMG (W463) Discuss the G55 AMG.
G55 squeak in front??????
Old 06-17-2014, 10:30 AM
RB1
RB1's Avatar
Various
Hi-
I can't figure out what is making a squeaking noise that can be heard inside the cabin when driving. It sounds like a metal-on-metal squeak...like a hamster wheel. It's only when the car is moving, and seems to be coming from under the hood. I tried to upload a movie of it but can't...can send it to you separately if you think you can detect it from hearing it.
Would really appreciate some help...it's probably a quick fix and don't want to spend $1k having a dealership look for it! Perhaps it's a common noise...
Thanks-
Rodger
Old 06-17-2014, 12:58 PM
RAKLAW's Avatar
2012 C63BS 2009 Ferrari 16M 2016 Cayenne turbo S 2019 G63
[QUOTE=RB1;6075747]Hi-
I just brought my 2014 G63 in for a metal sounding squeak/rattle from rear cargo area. I thought it was under the headliner. They kept the car for a day and correctly diagnosed the rear door latch and seals needed lubricating. 2 different part nos for lubes were used.
Maybe your hood mechanism needs a lube. These noises often seem like they come from one area but in fact are at another.. good luck
I take it you are off warranty
Old 07-14-2014, 12:53 PM
RB1
RB1's Avatar
Various
Thanks, I've had to lube the rear latches and doors as well a few times on this G55 and a G500 Grand Edition.
Does anyone know of particular areas that might need greased under the hood that could cause the metal squeaking noise inside the cabin?
Old 07-23-2014, 11:32 AM
zefpashko's Avatar
'08 G55 AMG
Squeaking near the front end can also be from a slightly loose hood latch. If the hood has some wiggle room once fully latched, the squeak may be coming from this. It can be fixed by adjusting the bump-stops on the underside of the hood (one on each side), so the hood closes more tightly. Hope this helps!
Old 07-25-2014, 10:00 AM
RB1
RB1's Avatar
Various
Thanks for the reply. I do have issues with my hood...MB tried to fix it, a body shop tried to fix it...but it's still not shutting properly and wobbles a bit when driving at high speeds. I'll have that fixed and see if it solves the squeak too...
Old 07-29-2014, 04:20 AM
BlackSL's Avatar
2013 G63, 2015 S500, 2016 C63 coupe
squeaks can be from the hood as mentioned and the engine mounting brackets.
I had mine fixed by service last week. Nice and quiet for now.
Old 05-05-2017, 11:02 PM
richview42's Avatar
G500 2014 model
Sqeeky noise from front of g500
Check the brackets supporting the radiator
Went weeks trying to get to the bottom of the squeaking noise when driving at low speeds. Not the suspension, not sway bar, not doors. Bloody radiator support!!
Old 05-18-2017, 07:59 AM
romebe's Avatar
05 G55 AMG, 08 CL65 RennTech
I have squeaking sounds while I'm driving as well, but it's more like whistling. My mechanic came to the conclusion that it was coming from the pulley of the supercharger
Old 11-21-2017, 11:04 PM
ChiefGu's Avatar
1956 Ford F100, 1973 Volvo 1800ES, 2008 MBZ C300, MBZ 2010 G55
Squeek
Still trying to get rid of mine. Sounds just like you described. My wife actually calls it the hamster sound. About 10 threads in this section there is a video on how they fixed the hood squeak with electrical tape.
I tried it with minimum results.
Good luck.
ChiefGu
Old 11-22-2017, 11:02 AM
paulunm's Avatar
2000 G500
Try this-
Quick Reply: G55 squeak in front??????
