General Mercedes Discussion Use this forum to discuss general Mercedes-Benz topics that are not specifically model related.
Help.
Old 06-25-2016, 01:44 PM
1997E320's Avatar
2000 E320, 2004 S430
Help.
2001 e320 sedan. Had the car detailed 1 week ago. After detail tranny went into limp mode.I Let the car sit for a week disconnected battery. P is still not showing on dash. The only way to shift to park is to release the brake (scary when the car rolls). If I have to replace the shifter assm does it have to be flashed to the vehicle as well? Or does the original just need to be flashed? How long does flashing take if necessary?
Old 06-27-2016, 11:19 AM
Mmr1's Avatar
2013 glk 350
Did they wash the motor or that area? Did you get codes read? It sounds like they got the transmission computer module wet. You might need a new module since it should be dry by now. Easiest would be a used module, new ones sometimes need MB to program them to the car. Get codes read
Old 06-27-2016, 12:35 PM
Mmr1's Avatar
2013 glk 350
I bet a power washer was used in the engine compartment , look at the TCM to see if wet
Old 06-29-2016, 07:19 PM
1997E320's Avatar
I only had the interior detailed. The code is P0705 range sensor circuit PRNDL input is what the code reader says
Old 06-29-2016, 07:23 PM
1997E320's Avatar
I have watched how to change the shifter assm. Apparently it is sensative to spills. The carpet was pretty wet when they finished detailing. If I change it do I need the shifter coded or flashed to the car?
Old 06-30-2016, 06:39 AM
Mmr1's Avatar
2013 glk 350
I have no idea , try drying it out
Quick Reply: Help.
