Voice Control Demystified
2015 E250D
For those of you wanting voice control in your car, please reading the following.
If your vehicle does NOT have the VCS buttons on the steering wheel, those will have to be added as well. If they do, chances are the VCS harness is not present in the car and this will have to be made. If you don't have the proper tools to make the harness, PM me and I can make it for you. The harness is NOT available ready made as of this post. To make your own harness, make sure you have the correct crimping tool. If you don't want to crimp your own wires, then order the pre crimped wires below.
TO make your own harness follow the guide:
PIN 16 of VCS housing to pin 1 of Microphone Housing
PIN 14 of VCS housing to pin 2 of Microphone Housing
PIN 6 of VCS housing to pin 3 of Microphone Housing
PIN 5 of VCS housing to pin 4 of Microphone Housing
PIN 15 of VCS housing to pin 5 of Microphone Housing
PIN 4 of VCS housing to pin 6 of Microphone Housing
PIN 11 of VCS housing to pin 7 of Microphone Housing
PIN 1 of VCS housing to pin 8 of Microphone Housing
Pin 9 of VCS housing to pin 9 of REAR sam P1 connector for power
Pin 19 of VCS housing to ground
Pin 18 of VCS housing to MHI pin 24
loop the fiber with the MHI module. Programming is required.
11 pieces of Wiring harness pre crimped. (with contact springs)
A 000 540 48 05
1 Connector housing 20 position, voice control
A 000 545 90 30
Cover, microphone array
A 000 545 93 03
1 Pin housing 8 position, microphone array
A 001 545 59 40
1 Pin housing, voice control
A 002 545 86 40
1Connector housing, microphone array
A 003 545 00 30
1Connector, ground
A 003 546 85 40
3 Plastic nut, M5
A 003 990 02 51
1 Contact spring, rear SAM
A 013 545 09 26
1 Bracket, seat heater control module
A 164 545 00 47
1 Cable, MOST fiber optic
A 164 820 20 04
1 Control module, voice control
A 203 820 82 85
A 000 540 48 05
A 000 545 90 30
A 000 545 93 03
A 001 545 59 40
A 002 545 86 40
A 003 545 00 30
1Connector, ground
A 003 546 85 40
3 Plastic nut, M5
A 003 990 02 51
A 013 545 09 26
A 164 545 00 47
A 164 820 20 04
A 203 820 82 85
SL600
06 CLS55, 07 GL450, 07 GMC Yukon, 06 Pontiac Vibe
I have the buttons, but my dealer's parts dept. can't find a part number for it, and keeps telling me that it is not available yet. Any suggestions?
