Sign in using an external account
| GL Class (X164) 2007-Present: GL320CDI, GL420CDI, GL450, GL550 |
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 |
Drives: '07 GL450
Finally got some trailering done
#2 |
Drives: '07 GL 450, '02 S 80 T6
Mel - you should rent that hauler out as a family unit. It looks big enough. Or bring it to LA when you come here and I can definitely find you some renters
#3 |
Drives: 2007 GL 320 CDI, 2008 M5
What kind of reprogramming are you talking about? Can't I just put a ball on my hitch and connect it to my trailer or is there more to it?
#4 | |
Drives: '07 GL450
Quote:
Your hitch is most likely factory installed so you should not have anything to worry about. Regards, Mel |
#5 |
Drives: 2004 RX330, 2008 Scion xB, 2001 Honda Insight Hybrid, 2010 Toyot Prius v ATP
Considering a hitch
I'm seriously considering a hitch for this unit, but the expense is pretty huge. Then again, since I plan to actually use this unit for towing, I would only go with the MB (dealer) installed unit as it has some really great safety features. This is particularly important with the IRS, since you can get your trailer yanking the GL's rear around if they get out of sync, but a quick tap on the brakes is supposed to use the stability control program to re-align the truck and the trailer.
Now, as for an electronic brake, wouldn't it be easier if the load is that big to use the hydraulic tongue brake (or whatever that system is called)? S |
#6 |
Drives: GL450
That's my opinion. The hydraulic brakes on my boat trailer are much better brakes and no brake controller.
#7 | |
Drives: 2007 GL320 CDI, 2001 TJ Rockcrawler, 2005 Scoobie STI
Quote:
Those are called surge brakes... They are satisfactory up to a point, but they are not as good as electric brakes through a controller. |
#8 | |
Quote:
Actually, I did some trailering yesterday and the lights on the trailer did NOT work even though I have a factory installed hitch. Do you have any reason why?
#9 | |
Drives: '07 GL450
Quote:
Regards, Mel |
| Tags |
| 16, 2006, 450, boat, connect, gl, gl450, rear, sam, terll, thule, towing, trailer, unit, working |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
