Beware of rear license plate bolts
2008 Ml350
Not sure if the rear mounting plate for the license plate is the same on the GL as on the ML, but,,, I have a 2008 ml350, and this weekend noticed that the (4) philips head screws that holds the license plate to the stainless steel plate bracket mounted to the tailgate are too long, even with the license plate frame in place. The screws actually contact the painted surface of the lift gate. I took off the license plate, and the stainless steel plate bracket, and sure enough, the screws are marking the paint on the liftgate. I am sure after a time of road vibration, the paint and primer will be gone, and the exposed metal of the lift gate will start to rust. I put 2 stainless steel lock washers under the screw head on each screw, this kept the screw from going in so far, and now it can not hit the lift gate. What happened to the engineers that build these things? if I noticed this, why would it slip by them? If these screws are supplied by the dealership, rather then the factory I can understand the oversight.
The screws are supplied by the dealers and this is not an uncommon issue. Unfortunately, a few of us have had this experience.
2008 C350
I can't stand when dealers do crap like that. If I were you, I would ask the dealer to install some that fit.
The only thing wrong with my bolts it that they rust.
2011 E350 Cabriolet..White and Almond Mocha
I checked my GL and although I cannot really see behind the plate, there is clearance with a piece of cardboard so I do not have your problem. Also, knowing the dealer I am confident it would not happen.
Give me a break--this is stupidity at the dealership, nothing more.
The Alabama cars are different than the Euro cars, which could use inch-long screws if necessary.
I suppose the Alabama design is better, as the screws don't penetrate the tailgate like the screws on the cars penetrate the trunk lid.
I was installing my plates this friday with new (non-dealer frames) and did notice this. While there is some clearance between end of bolts and body in th erear it seemed the dealer might have applied some pressure when mounting the plate holder and pushed the ends of the bolts into the body leaving an indententation. I was much more aggravated at the front plate holder (required here in NJ) where the dealer seems to have eye balled the installation of the plate holder and screwed 4 screws directly into the bumper one of which was put in at an agle making for a very messy installation. Any change will now require filling in the hole and paint work. I am very picky about these things and its really annoying when dealer does not take the time to do these things right. Unfortunately there is no going back.
2008 GL 320, 2007 Silverado LTZ C3500 Duramax Turbo Diesel
did not have the choice
I sympathize with you. My dealer did not install my plates since they are 3 hours away. I did it myself and wasn't crazy about drilling holes in the front bumper. They said they didn't install the bracket because some people choose to run without it, illegally here I might add.
We told the dealer NOT to install license plate frames and they were not on while we went over the car. Somehow, the rear got installed before we drove away...
All four screws were too long and marked the paint! Photo showing after we took the stainless bracket off.
2008 GL320CDI
Wow, I'm just walking back into my office after a trip to the dealer for this very problem. I found the same problem on my new GL this weekend All four screws have drilled their way right through the bloody paint. I replaced them with shorter socket-head stainless screws.
I have to agree with lkchris - this is pure stupidity on the installer's part. I cannot imagine doing this without noticing the screws were fouling on the car body. Inexcusable.
1 Post
2008 GL320cdi
After reading this thread, I went out to look at my plate and sure enough I have screws that are too long. I picked up my car 2 weeks ago and the rear plate was swapped by the salesman while I was filling out paper work. Back to the dealer for touch-up paint!
08 GL450
Show it to your sales person - they should COMP you the touch up paint .
2008 GL320CDI
08 GL450
OTOH, I'd rather just touch up those four tiny basically hidden "points " myself . You know how it goes , body shop will have to spray a wide area and there could be paint overspray, the hatch's release latch won't feel the same after they remove and reinstall it, the paint won't match when you look critically at it from the side ....but the shop guy will say it's fine and they're done .
1 Post
2004 RX330, 2008 Scion xB, 2001 Honda Insight Hybrid, 2010 Toyot Prius v ATP
Years ago, my first Lexus was an SC400, Barolo Red (I think they called it - a magnificent metallic deep red, almost an oxblood color they no longer carry). When I got it, there were swirl marks all over the car. I argued for some time about the fact that I wanted what I paid for, a new car with proper paint. At one point, the district manager met me at the service drive and said, "What do you want me to do to make the paint right?" My response should have been, "I really don't care what you do to make it right, other than giving me the car I paid for with the paint I paid for." Instead, I whimped out and told them to detail it and try and get the swirls out.
I'm not a paint expert, but was much less so then, so how the heck would I know what would make the paint right? I defer to experts. I don't apply "touch up" paint because no matter what I do it looks like white-out on the car.
STP
2011 C300 Sport 4Matic, 2004 Audi A4 1.8T Quattro Ultrasport, 2010 Subaru Forester
Hate to bring this thread back but unfortunately I have this problem on my c300.
Two incorrect, non-oem screws installed on the rear when I bought the car went straight through the trunk lid.
My dealer has agreed to fix it, but I'm just curious as to how others have approached the repair.
Did you have your trunk lids repainted or was it a bit more simple of a fix like a spot repair?
Unbelievable that this stuff can happen!
To the op. You can't recognize a good thing when you see it- can you
Be thankful to the piston gods that you were able to remove the screws without spinning the junky backing plates in the trunk lid. When that happens- you have to tear apart the trunk lid.
2010 C300 4Matic
So, will someone please confirm complete specifications for the front and rear license plate fasteners?
Thank you!
