Go Back   MBWorld.org Forums > Mercedes-Benz SUVs, Trucks, Vans, Diesels, Other > GL Class (X164)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors
Welcome to MBWorld.org Forums
GL Class (X164) 2007-Present: GL320CDI, GL420CDI, GL450, GL550
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 03-04-2011, 02:32 PM   #1
Tire wear question
Our 2011 with 20" Bridgestone runflats has 5000 miles on it. The front right tire is featuring slightly on the exterior side only. Not too noticeable but it can be felt if you run your hand over the tire.
Is this something that others are experiencing? Or potentially an alignment issue? These tires are fairly expensive so I don't want to wait too long. Thanks.
To remove this ad, register today or login if you already are registered!
dougpark714 is offline   Reply With Quote
Old 03-04-2011, 04:16 PM   #2
Drives: 09 GL320 Bluetec
My Goodyear Runflats slightly feather in the front but they smooth out when you rotate them to the rear. Each outside tread is slightly lower in the front than in the rear but you have to look real close to even notice it. But... if your wear is different on the right front from the left front you have a problem (and I probably don't need to tell you that). I would definitely be sure to rotate every 5000.
43221B is offline   Reply With Quote
Old 03-04-2011, 10:14 PM   #3
Drives: 06 Cayman turbo
If you are feeling the raised edges of the tread blocks in one direction and not when going in the other, then you have "Cupping" or "Scalloping" which could be caused by suspension or alignment issues. Try a web search for "Cupping tires"...it will explain it.
__________________
Previously: 08 GL320 CDI, 07 S550, 04 E55, 01 CLK55, 99 ML320
ima55r2 is offline   Reply With Quote
Old 03-10-2011, 01:46 AM   #4
Thanks guys. Took the car in and they did an alignment free of charge. Camber was slightly off on right side causing the light feathering that could be felt but not visible. But caught it early enough to not damage the tires permanently. These runflats are expensive so good to check on the wear regularly.
This is the 3rd new car (both mb and bmw) that required alignment correction within first 3000 miles. Wonder if the alignment could be affected from transport and handling.
Old 03-10-2011, 10:59 AM   #5
Drives: 2011 GL350 Bluetec, Irridium over Black Leather
Quote:
Yes.
- Mark
mdadgar is offline   Reply With Quote
Tags
3000, e55, feathering, feathing, mercedes, tire, tires
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright © 2001-2012 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
SEO by vBSEO 3.5.2
