GL450 air springs
Old 12-23-2014, 11:35 AM
  #51
BlownV8's Avatar
Received 1,003 Likes on 810 Posts
E55, GLS450, GL63, GLE350
Looks good. The airmatic is worth the small issues like airbag changes to me. ABC suspension......that's a whole other issue.
DaBenzGL550 (07-11-2018)
Old 12-23-2014, 02:39 PM
  #52
N_Jay's Avatar
2007 W211 E350 4Matic / 2008 X164 GL320 CDI
Originally Posted by vdub18t
Seeing the many air bag failures on the forum led me to investigate totally replacing the airmatic on my 2009 GL. Basically after a little info digging, I decided to source some ML front coil spring/struts and rear springs. Installed. Have been loving the ride, handling (way less wobbly feeling), and comfort of knowing the vehicle wont be lowered in the morning when i go out to get in it.
Any error codes?
Old 12-23-2014, 03:12 PM
  #53
vdub18t's Avatar
GL 450
Originally Posted by N_Jay
Any error codes?
Well, we agree to disagree. I much rather have a system that rides better, in my opinion, than the airmatic and not have to worry at all about airbag failure, compressor failure, or air line failure. But to each he's/her's own. 😄
Old 12-23-2014, 03:17 PM
  #54
vdub18t's Avatar
GL 450
Any error codes?
Oh. Only error code is a "Malfunction" code. With a pic of a gl. No worries as i simply hit the left steering wheel up or down button and it disappears. My theory is that I only need to secure the level sensors horizontally and that should be negated. Just lazy at the moment.
Old 12-23-2014, 03:33 PM
  #55
N_Jay's Avatar
Glad you like it.
I like mine to self adjust for load and towing.
The following 2 users liked this post by N_Jay:
GL450fanboy (09-07-2022), Prince Somorin (07-14-2022)
Old 12-23-2014, 07:13 PM
  #56
vdub18t's Avatar
GL 450
Glad you like it.
Duly noted. I have towrd my enclosed 6x10 trailer enclosed with my racebike and it only slightly squatted. Estimated about 800lbs at the hitch.
Old 12-31-2014, 11:02 AM
  #57
2010GL550's Avatar
GL550
vdub18t - how much was the cost of the conversion parts/kit? This could be a great alternative for those of us tired of replacing air springs.
Old 12-31-2014, 04:18 PM
  #58
vdub18t's Avatar
GL 450
Everything will run @ $1600 ($1200 front and $400 rear). I found the best online prices here: www.parts.com
Old 01-13-2015, 12:03 AM
  #59
Cooljust's Avatar
2008 GL450
I ordered the Arnott replacement air shocks but cannot get the suspension bolts off. For those that have done it themselves, what's the trick to loosening to lower control arm bolts?
Old 01-30-2015, 12:32 AM
  #60
GL450inYYC's Avatar
2008 GL450
2008 GL450 Airmatic Question
Hello! First post hopefully this is the right area. I have a 2008 GL450, the front left sags when the vehicle is turned off. However if I raise the vehicle there is never a issue with air loss. Ideas?
Old 01-30-2015, 04:58 PM
  #61
BlownV8's Avatar
Bad air strut.
Old 02-06-2015, 07:50 AM
  #62
a-v-ator's Avatar
2011 GL550
I have a 2011 GL550 with 102K miles, original owner. Recently I noticed that the left rear of the car down in the morning. I start the car and everything levels to normal. After driving, parking and returning to the car sometimes the left rear is down, sometimes not. I took the car to MB and they diagnosed that both rear bags needed to be replaced for a outrageous cost. Found arnoutt and am ready to pull the trigger. Wanted to do more due diligence first. Today I go out to the car in the morning and the entire left side is down. By the way the right side has never been down. Will one leaky bag cause this or is there more to the problem? One thing I have considered is that the battery is original. In the past I have heard the pump come on for a brief second or two while parked in the garage to level. I no longer hear this. Is is possible that the AMPs drop on the battery and the GL computer doesn't allow the pump to kick in? Other than spraying soapy water on the bags is there anything else that I can test before I start replacing bags? I do not believe that MB diagnosed this correctly.
Old 02-06-2015, 09:51 AM
  #63
BlownV8's Avatar
The Arnott airbags are cheap and the procedure is easy. Just replace them both and be done for a few years.
Old 02-06-2015, 12:42 PM
  #64
Popo's Avatar
2007 GL450 2005 C55 2002 C32 sold 2001 ML320 sold
for Cool Just - There is a reverse torx bolt you need to backoff, while holding the suspension bolt. BOTH of these are on the same side where the bolt attaches, so you cannot use a socket wrench to do it. I did it by using a crescent wrench to hold the "outer" bolt, and loosened the reverse torx with the appropriate size. You may have to clean the dirt out to see the reverse torx socket.
Last edited by Popo; 02-06-2015 at 12:43 PM. Reason: specifying person to respond too.
Old 02-06-2015, 05:24 PM
  #65
BlownV8's Avatar
You don't need that for the rear.
Old 02-09-2015, 04:23 PM
  #66
a-v-ator's Avatar
2011 GL550
I had some time this weekend to get under the car and sprayed bags with soapy water, no leaks. Also discovered that I can raise the car (using the raise feature) and the bags hold air and suspension stays inflated. But when raise feature is lowered, suspension sags after 30 mins or so. Suggestions?
Old 02-09-2015, 05:42 PM
  #67
vntgspd's Avatar
Porsche 911
I have the same issue. It seems to be time and temperature related. Mine will drop overnight in colder weather (sub 60's) but stay up ALL day with no issue. If I raise it it stays up. I have pulled the codes with no issues and also swapped the height sensor side to side. I also could not find a leak with soapy water.
I think there is a tiny leak in the bladder near the fold. When I raise the car I think it "seals" and when it's cold it may leak more. Not really sure.
I'm with BlownV8 and will be replacing it soon. A minor leak like mine is really just a nuisance but if it leaks down within an hour then fix it right away as you will be running the risk of overheating the pump.
Old 02-10-2015, 01:38 PM
  #68
fqadri's Avatar
2007 GL450
I had the Malfunction error with the front being low the back seems fine. I took it to the dealer and they are asking for $3995 to replace front shocks and air struts. I'm sure this is not reasonable. I took to another mechanic and he said only air shocks need to replaced any advice?
Old 02-10-2015, 04:03 PM
  #69
N_Jay's Avatar
Lots of threads on the Arnott replacements.
That price is unreasonable.
Old 09-16-2015, 04:17 PM
  #70
Oluwafemi's Avatar
GL450
slight Tilt front passenger side when I drive GL450 2008
Hello I drive a gl450 2008, when I park it for days nothing seems to go wrong everything is fine the airmatic suspensions are ok, but once I start driving, the front passenger side starts to tilt like there's a leak of some sort, I'm confused cause reading the thread I would believe if the airsprings were leaking it would lose air over days and collapse, mine doesn't do that it only tilts when I drive it
Old 09-16-2015, 05:09 PM
  #71
N_Jay's Avatar
Bad level sensor or bad air valve block.
Old 06-02-2016, 02:47 PM
  #72
dvdport's Avatar
GL350, 2010
Reviving an old thread here as I need to know exactly what happened if I did not disconnect the Level sensor plug. I have a 2010 GL350 and the setup is different. I cannot find the plug behind wall fender well liner indicated in the Arnnot video.
The attached instruction clearly indicates to "Disassemble the level control sensor rod" instead of the plug.
Anybody can tell me which is the correct way to do it? and in case of the "sensor rod", what will happen if I do not "Disassemble the level control sensor rod"?
File Type: pdf
Old 06-02-2016, 03:19 PM
  #73
N_Jay's Avatar
They are probably concerned with damaging the sensor.
Old 06-02-2016, 03:39 PM
  #74
dvdport's Avatar
GL350, 2010
[QUOTE=N_Jay;6821210]They are probably concerned with damaging the sensor.[/QUOTE
Anybody did the job without disconnection and no damage is caused?
Old 06-02-2016, 05:35 PM
  #75
dvdport's Avatar
GL350, 2010
I have separated the upper steering triangle without disassembling the level control sensor rod or disconnecting the level sensor plug and worried if I have damaged the level sensor already. The upper steering triangle just went up after the separation by itself. Anyone can let me know because I am concerned that I may need to change the sensor assembly if I damaged it.
Quick Reply: GL450 air springs
