08 GL550 amp remote wire install with Logic7
Old 11-25-2011, 07:56 PM
BuyingFoil's Avatar
2008 Mercedes-Benz GL550
Hey guys I have a question regarding installation of the remote wire for my amp in my 2008 GL550. I wasn't sure where to hook it up to in the back of the vehicle. I was going to hook it up to the 12v accessory outlet, but turns out that it's on all the time. Do you guys have any ideas?
Old 12-01-2011, 06:59 PM
lstoker's Avatar
MB GL450, BMW 335i
That's is where I was going to hook mine up as well, assumed it was switched.... That what I get for assuming. I will look this weekend and let you know if I find a better solution.
Just curious, where did you tap your speaker inputs for the amp at?
Old 11-08-2014, 02:23 PM
vdub18t's Avatar
GL 450
Remote wire location?
Old 12-22-2014, 05:23 PM
dh465's Avatar
2008 gl 450
So what ever happened with this? I have no idea where to go to run a remote wire.
Old 12-22-2014, 07:58 PM
vdub18t's Avatar
GL 450
I actually tapped into the remote wire tied to the factory amp located in the rear, right cargo area under the factory 6 inch woofer. Sorry, I don't remember the exact wire. You will have to test the voltage on each wire. Of course it will be the one that is 12v when the radio is on and 0v when the radio is off.
Quick Reply: 08 GL550 amp remote wire install with Logic7
