Go Back   MBWorld.org Forums > Mercedes-Benz SUVs, Trucks, Vans, Diesels, Other > GL Class (X164)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors
Welcome to MBWorld.org Forums
GL Class (X164) 2007-Present: GL320CDI, GL420CDI, GL450, GL550
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 12-06-2011, 07:14 PM   #1
Drives: 2011 GL350 Bluetech, 2000 Porsche 911 C2, 2005 Honda S2000
2011 GL350 rough ride
I've noticed the ride quality has deteriorated significantly since I bought the car 14 months ago. I've put 24,000 miles on the car but the stock tires appear to have plenty of tread left. I know the run flats are known to compromise ride quality but this seems worse. The car doesn't ride smooth over bumps --- alot of thudding felt and heard over road bumps, even change lane markers at lower speeds. Tires are currently shown at ~30psi (45-55 degrees in Northern California). I bought this car with the adjustable air suspension option. Wondering if something is going on with the suspension, the run flats get worse over time, and/or if anyone's had similar issues. Have an appt with the dealer next week.
To remove this ad, register today or login if you already are registered!
blee911 is offline   Reply With Quote
Old 12-06-2011, 07:53 PM   #2
Drives: 2008 GL 320 CDI, 2004 VW V10 Touareg TDI
I've not heard of this type of issue, but if you can talk the dealer into temporarily slapping another set of tires and wheels on then giving it a test ride you should be able to easily tell if the tires are the culprit. That option is a lot easier than changing suspension control black boxes!
Fourdiesel is offline   Reply With Quote
Old 12-06-2011, 09:39 PM   #3
aeggroup's Avatar
Drives: 12 E350BTC, 13 GL450, 11 C3004Matic
No doubt it's your tires. I changed my run flats when they were about 5K miles and the difference is huge . I can imagine how bad they are when they get to 25K.
aeggroup is online now   Reply With Quote
Old 12-07-2011, 08:41 AM   #4
Drives: 2013 ML550 twin-turbo, SLS, 2011 E 63 AMG (sold), 2012 CLS 63 AMG.
Quote:
I'm in Michigan, and i've noticed the same.My GL has 18K miles on it. My steering wheel has gotten very loose(took it to the dealer, they tightened something, it was fine for a week, then got loose again). And when ever i go out a small pot hole, i can hear the car going over it, much louder than my 2011 Ford Edge Limited(has 11K miles on it).
Im taking it in this week, Friday or Saturday. Im pretty good friends with the head mechanic there. I feel like something in the front suspension is broken. I drove my neighbors GL about 2 days ago, and its not nearly as bad as mine. I'll keep you guys updated!
John
jchochla is offline   Reply With Quote
Old 12-07-2011, 02:43 PM   #5
Drives: '07 GL320CDI
Reduced tread depth (due to wear) reduceds tire's ability to "squirm" and provide soft, quiet ride.
So does fact the rubber is aging and losing pliability.
__________________
Kent Christensen
Albuquerque
'07 GL320CDI
lkchris is offline   Reply With Quote
Old 12-07-2011, 03:05 PM   #6
Drives: 2011 GL350 Bluetec, Irridium over Black Leather
Quote:
No.
Yes.
Also, colder weather = stiffer rubber = harder sidewalls = rougher ride.
- Mark
mdadgar is offline   Reply With Quote
Old 12-07-2011, 04:26 PM   #7
aeggroup's Avatar
Quote:
- Mark
Can't agree with that. Somehow my "regular tires" ride is still the same - winter or summer.
Old 12-07-2011, 04:29 PM   #8
Drives: 09 GL320 Bluetec
Also, as it gets colder, any cracks that have been in the road all summer are going to get wider as the asphalt contracts making them more noticeable. I have 33,000 on my Goodyear runflats. I have noticed the same thing every fall/early winter.
43221B is offline   Reply With Quote
Old 12-07-2011, 07:05 PM   #9
Quote:
Different tires, different rubber, etc etc etc.
I could be wrong (unlike lkchris), but given the already stiff sidewalls and hard rubber content of the GL tires, it makes sense.
- Mark
Old 12-08-2011, 06:55 PM   #10
GL350 rough ride
Thanks for everyone's feedback. I'm looking forward to what John finds out with his GL with 18K miles. I'll also keep you posted on what happens at the dealer next week.
For those of you who changed out your run flats, what tires did you go with and what do you plan to do in the event of a flat tire? Did you purchase a tire repair kit? My old Cayenne S came with no spare and non-run flats but had a tire repair kit which included a small compressor that connects to the battery. Seems crazy and high impractical coming from Porsche but I actually did have a flat tire once and used the compressor so that I could make it to a nearby tire store.
We make a lot of trip to Tahoe during ski season. How does the ride compare for Scorpions vs the stock runflats. I hear snow tires aren't great when you don't need them but I can't imagine anything being worse than the stock run flats.
Old 12-08-2011, 07:44 PM   #11
I'll for sure get back to you on what they say. I'll take it in tomorrow or Saturday.
Old 12-08-2011, 08:57 PM   #12
aeggroup's Avatar
I changed my original Bridgestones to HANKOOK - VENTUS ST RH06 285/50R20. They were much cheaper than original 275 size. As I said before - the ride is totally different - no road noise and very smooth.
Also I bought this repair kit from ebay :
http://www.ebay.com/itm/400247804177...ht_1702wt_1110
Old 12-09-2011, 01:53 PM   #13
Thanks! How many miles have you put on the Hankooks and how do they look? Not too wide for the stock rims? The 275/50 Goodyears already stick out a bit.
Old 12-09-2011, 05:48 PM   #14
Drives: 2006 E55, 2007 GL450
Mine had an issue like this where the ride deteriorated. It wasnt the wheels, rather it was the rear shock absorbers that started leaking oil .
I first thought that being airmatic, that it didnt have/need shock absorbers - but yes - it still has those in there for dampening. When they went south, the ride was worse than my 4Runner. After it was fixed, it was like night and day..
HIGHMILE E55 is offline   Reply With Quote
Old 12-09-2011, 07:07 PM   #15
Highmile, before the problem got solved, were you able to feel if you went over a bump or pothole in your steering wheel? Because my car's been in already once. But i have my work schedule pushed back, so i will either take my GL to the dealer tomorrow (sat morning) or next week.
Old 12-10-2011, 12:03 PM   #16
aeggroup's Avatar
Hi.
I put about 2K miles..not a lot. I wouldn't say they look much different than stock tires. Here is couple pics I just made :
2011 GL350 rough ride-img-20111210-00123.jpg   2011 GL350 rough ride-img-20111210-00122.jpg   2011 GL350 rough ride-img-20111210-00121.jpg
Old 12-11-2011, 09:30 PM   #17
Quote:
Yes I especially felt (and heard) the bumps and potholes more than usual. Now that I think about it, I remembered that they also replaced one ball joint. The symptom of the ball joint was that the car did a slight wobble, when going over a pothole.
It was really night and day after they fixed the suspension issues - you can definitely tell the difference. It made me realize again how amazing this thing is when everything works the way it should...
Old 12-11-2011, 11:33 PM   #18
Sounds good. I made a appoitment for this Thursday. I'll drop it off and let them have it untill they fix the issue. While the GL goes to the shop, I'll drive my E. I'll keep you guys updated!
Old 12-12-2011, 01:22 PM   #19
350 rough ride
Just dropped my car off at the dealer in San Jose. Even the C-class loaner has a much smoother ride than my GL! Will keep you all posted.
Old 12-12-2011, 07:02 PM   #20
Dealer found nothing unusual. 2 techs drove my car. Service advisor said I could come in and test drive a new GL for comparison. I'll let you know what I find. I'm certain the ride wasn't like this before but if it is a function of run flat wear then I can see how MB would classify this as within normal operating performance...not that I agree. I never would've considered buying a GL if I knew the ride would be like this after 1 year.
Old 12-12-2011, 07:42 PM   #21
My Goodyear Runflats have >33,000 and they are no different than new in terms of ride quality. I do think the sidewalls might get a little stiff when it is cold but really not too noticeable.
I'm pretty sensitive to how the tires feel too. After my last service (30,000 miles) I left for a 5 hour trip. I almost immediately noticed that the tires felt harsh. After hours of feeling every little imperfection in the road, I got to my destination and checked the tire pressure. As I had assumed, the MB tech had put 38 lbs of pressure in my rear tires (as they always do, I guess they must think my toddlers are fat or something). I brought the pressure back down to 32 and all was fine.
I would take the service adviser up on his/her offer and bring your own tire pressure gauge with you.
Old 12-12-2011, 07:45 PM   #22
aeggroup's Avatar
No reason to worry. Just change the damn tires and forget it.
Old 12-12-2011, 09:29 PM   #23
^There's a solution...lol.
Old 12-13-2011, 11:59 AM   #24
Finally got an honest answer from one of the Sales guys and he said his MB has the same problem and it's those darn runflats. The service guys will never admit problems like this.
Thanks for all the inputs.
Old 12-13-2011, 12:40 PM   #25
I would love to go to a regular tire, but Tire Rack shows no all-weather options in the same size that are not the GY or Bridgestone run flats. Really? Suck.
- Mark
Tags
2011, 350, air, buy, changing, flat, flats, forums, gl, gl350, normal, options, run, suspension, tires
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright © 2001-2012 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
SEO by vBSEO 3.5.2
