Service A Question
Old 05-19-2012, 07:57 PM
KYBRIGGS82's Avatar
GL350
Service A Question
I have a 2012 GL350 with 1200 miles on the vehicle.
I have always changed the oil on a new vehicle at 1000 to 1500 miles to safeguard against metal shaving contaminants in a new engine.
What is the opinion of fellow forum members regarding this strategy to protect the long term operation of the GL's diesel engine?
Old 05-19-2012, 09:48 PM
alx
alx's Avatar
Follow the schedule created by the people that created the engine.
When was the last time you heard about a modern engine being the limiting module for the longevity of a vehicle?
Old 05-20-2012, 12:22 AM
KYBRIGGS82's Avatar
GL350
It seems in the past I have always felt a new piece of equiptment contained small particles of contaminants which needed to be flushed after 1000 miles to help ensure longevity to an engine.
Whether American or European made vehicles, I have always serviced these automobiles early for piece of mind and for no other reason. Maybe it's time for a change of direction regarding early services on the GL350 but then again it's my wife's car not mine so I'll pass long the advice.
Old 05-20-2012, 05:02 PM
mschirmer's Avatar
'99 CLK430 '02 SL600 Silver Arrow '14 GL350 Bluetec '80 Rolls-Royce Corniche Coupe
Extra Oil Change
It will certainly do no harm - except to your wallet. Plan on spending around $125 for DIY (MB filter is about $25 and Mobil 1 Formula M does for almost $10/quart). An MB dealer probably gets $200 to $250 to do it.
Old 05-20-2012, 05:23 PM
aeggroup's Avatar
2023 Range Rover, 2020 MB S450
I changed oil first time at 5000 miles on odometer. Our dealer had promotion - oil change cost me $105 at that time. After that I did A service at about 11K miles and will follow MB notification in the future. There is no point to change oil every 5K miles anymore.
Old 05-20-2012, 06:55 PM
nynd's Avatar
2018 E63S
For piece of mind, you can do it early - I did. Oil capacity is about 9 quarts so yes, costs a bit, but if you do it yourself, not a big deal - cheap insurance for longevity.
Old 05-21-2012, 03:45 AM
stickygreen's Avatar
'97 E320
Do not change the oil too early. These motors come with special break-in synthetic oil from the factory (forget the spec...something like 229.1) that should aid in a proper break in.
Old 05-21-2012, 07:29 AM
KYBRIGGS82's Avatar
GL350
Regarding a break in additive to the engine from the factory then when is an early oil change appropriate ? I was thinking at 1500 mile to 2000 miles.
Old 05-21-2012, 12:13 PM
aggst1's Avatar
2011 GL450, '06 R500 traded, '08 ML350 sold
As far as I know there is no early oil change appropriate for this type of engine. Such practice is a thing of the past. There is no such thing as metal shavings as in motors of early years. Wouldn't the manufacturer require it if it was an issue?
Old 05-21-2012, 12:15 PM
'97 E320
I'd leave it in until the suggested interval of 10k, but definitely no less than 5k. Any less would more-or-less negate the effects of the break-in oil (likely with higher ZDDP)
And the oil filter should pick up all th "little metal pieces"
Old 05-21-2012, 12:35 PM
KYBRIGGS82's Avatar
GL350
Thanks.. I'll wait for 5,000 miles or if a service light indicates service prior to the first 5,000 miles.
Quick Reply: Service A Question
