Charging battery - extended vacation
2011 GL 350-Lighting Pkg-P2-Parktronic-Blind spot assist-Heated everything-Running brds ,etc
I have purchased the MB charger (CTEK- 3300) and would like to keep my 2011 GL-350 charged during my extended vacation.
I hope it is OK to keep the charger connected to the vehicle for 3 weeks continuously?
Not sure if this recommended and since this is the first time I am going to keep it charging, will there be some kind of heat buildup that I should worry about?
TIA
TIA
Thx guys... didnt want to take chances without the charger, in case I have to stay longer out of town.
TIA
TIA
On the first absence when I returned, one of the chargers was in the 'abort' mode. To reset, power to the charger needs to be cut for an instant. Now, I use inexpensive plug-in, wall outlet timers, set 12 hrs on and 12 hrs off so that if an abort happens again, it will be self correcting..........
Timers are an excellent solution - and not just for the abort issue. If the timer is set to, say... 4hr on, 20hr off... any question of excess temp goes away.
