Highest Mileage on a GL?
Old 10-27-2014, 10:59 AM
bha
bha's Avatar
13 GL350, 14 SL550
Just did the 150k mi service (almost 250,000km)
Since I bought the truck 2 years ago with 107k miles, I have done the following:
all 4 corners air suspension (2 struts, 2 rear airbags)
Diesel particulate filter (differential pressure sensor)
Glow plug module
Front brakes/rotors
One set of tires.
Other than that, all has been routine maintenance:
Oil changes
Cabin & engine air filters
Fuel filters
Coolant flush just done as part of 150k miles service
Power steering fluid partly replaced (drain/refill reservoir)
Bulbs/Xenon upgrade kit
The only items I have done that are not listed in the MB regular maintenance manual are the air suspension and the particulate filter sensor and glow plug controller.
Truck looks and runs like brand new except one thing.. popping noise from the transfer case (chain is jumping teeth). I have a used unit and am going to try to install it in the truck this weekend.
Not bad for 150k miles....
Quick Reply: Highest Mileage on a GL?
