2007 GL450 Bluetooth/Media Interface Plus
07 GL450 I have the Evo4G, Android 2.3.5 and the newest all-black puck and I've tried everything (including Bluetooth file transfer) and no luck. Any help would be greatly appreciated.
2007 GL450
2007 GL450
2015 Ram 2500, former 2013 GL350, 2007 GL450
What's the problem?
I assume the bluetooth works fine, but you can't transfer contacts? There are several threads on this forum, some contradictory, but I've never gotten an Android phone to sync contacts and have tried many hints and techniques.
Yes the bluetooth works great! Sometimes only some of the contacts transfer, but mostly the do not. I did find this. I think I will try it.
Originally Posted by dannieboiz [IMG]file:///C:/Users/Lori/AppData/Local/Temp/msohtml1/01/clip_image001.gif[/IMG]
I'm sure someone has already got this figured out but I searched and saw no instructions for our cars, just giving back to the community....
1. Downloaded "Bluetooth file transfer" app from market . (It's Free)
2. Exported contacts to SD card ( in menu options within contacts)
3. Open Bluetooth File Transfer (it'll look like your file explorer so don't be confused) Navigate to where you exported the .VCF touch and hold the contacts (.vcf) and select "send via bluetooth.
It'll ask you to select a device, if you select (MB PhoneSystem) it will fail, instead select UHI-S**.
I borrowed the instructions from the android forum but had to figure out the MB PS VS UHI device.
Took no more than 3 or 4 minutes to sync 200 contacts that I have.
