Adjust the Headlight Beams
2007 GL450, 2006 Porsche 911, 2004 VROD
Anyone know how to adjust the headlights on a non HID headlight in GL450?
My low & high beams don't project out far enough and I'd hate the take the car into the dealership just to have the lights adjusted.
appreciate your help.
Received 1,003 Likes
E55, GLS450, GL63, GLE350
The holes are on top. One does vertical and the other does horizontal. Look on top of the headlights where the support brace runs. The screws are white nylon and are set below the support brace above the headlights.
Take to an open flat area at night. If you have a long flat driveway, that works great. I aligned mine so it is below the trunk and windshield of the cars in front.
Yup497 (08-09-2019)
'Sarge' (03-16-2024)
Yes but if you're going to so it, please use oem replacement HID housings/projectors. The halogen projectors were never meant for an arc light source (HID) and were designed around a filament light source. By installing HIDs in halogen housings, one of two things will result:
1. You will cause excessive glare to oncoming traffic
And/or
2. You will cause excessive foreground light that will give the illusion of better visibility, but in fact will kill your distance vision due to constricting pupils
And/or
And/or
And/or
The first night I drove my GL I thought I wasn't going to make it home. The stock halogens and aiming are horrible. They have very little usable light at night. By far the worst of any car I've ever driven. Yes, they are that bad!
That is not my experience with the GL halogen projectors at all. I posted a pick of the cutoff and throw after my conversion. It is perfect. Never had anyone flash me and I could not be happier with the results. The results are truly night and day with he HID conversion.
thanks BlownV8 for the help how to adjust the beams. is there any separate screws for adjusting high beams?
Can you do the HID conversion on lows & not highs?
Found out my housings are aftermarket from a company in China called nsfauto.com and the adjustment tabs are broken. I don’t know if I should go back OEM or get another aftermarket housing?
2007 GL450
OEM. Get them used. If you're patient, you can get very good results with LED bulbs in the OEM housings.
It may not even take that much patience anymore. My experience is a couple of years old now.
My car came with halogen do I have to get halogen housings?
also I’ve been looking at a HID kit...is that better than LED?
2007 GL450
You might try to get the bi-Xenon housings, but no way would I do that.
You'll kick off a firestorm if you start discussing HID vs. LED. I understand the hate, because there used to be a ton of lousy LED bulbs out there. I was able to get LEDs to work very well, however, so I think the haters are just behind the times. I've driven cars with HID and my LEDs are every bit as good. Check my thread on LEDs to learn more.
HID costs a lot more, and I think people that invest the money are unwilling to consider that they overpaid, and that's why LED BAD. I don't blame them. I just present facts.
HID might be comparable in cost if you include the OEM housings. Looks like you'll be doing well to pay $100 each.
I have stock xénons and can’t see F—k all
can I just replace the bulbs with HID or LED
the bulbs I have have the square ballast stuck to them
thanks
thanks
2007 GL450
Note: If I remember correctly, the headlight adjusters are weird. Each is at a 45 degree angle. You have to adjust both screws together. Make it so the break in the beam cutoff, where the beam angles up to the right, is centered.
SPONSOR/MBworld Guru
Yup497 (08-10-2019)
2010 GL550 | 2020 S560
I have the OSRAM CBB bulbs and absolutely love them. But I also opened the headlights and replaced the projectors with EVOX-R projectors. Low beam is hitting 817 lux and high beam at about 1015 lux.
I also added a switch back strip in the front turn signals from Profile Pivot.
2010 GL550
2010 GL550
2010 GL550
2010 GL550
Yup497 (08-11-2019)
Looks amazing! Are you using CBB bulbs? Our cutoffs are crisp and its awesome with the cornering headlights.
When my headlights reflect off signs I'm getting the exact color the brand new GLS gets w LED headlights. That purplish blue hue at the cutoff line. Thats where the projector bends the light.
Hands down the best performing projector I've ever used.
Ill try to grab some shots in the morning of the illuminated road ahead.
2010 GL550
2010 GL550
why did you we place your?
