265/50/20 or 285/50/20 Help!
Old 10-10-2012, 07:46 PM
collman's Avatar
Lexus GS300
Smile 265/50/20 or 285/50/20 Help!
I have 09 GL450 w/20" wheels. I need to get new set of reg tires from run on flat. I don't want to get current 275/50/20 size, because 275 is more expensive than 285 or 265, and only few choices out there.
Since I'm in WA state, have to consider snow weather.
My questions are;
- Does 265 work better than 285 on snow? and Does it make big difference?
- GL has TPMS, is it OK to mount the tires at Costco? or need to bring tires to
the dealer? I'm not sure since I really don't know about the car.
Thanks in advance.
Old 10-10-2012, 08:09 PM
xxGenericSNxx's Avatar
99 ML430, 01 CLK55, 07 R63, 15 E63 Wagon
Costco should be able to deal with TPMS. But honestly not a big fan of Costco as they consistently scratch my wheels when mounting and dismounting the tire from the rim.
It'd be helpful if you put the city and state in your profile so we can better assist you.
Old 10-10-2012, 09:37 PM
collman's Avatar
Lexus GS300
I'm in Spokane, WA. Maybe better do at Discount Tire or similar store.
Old 10-13-2012, 03:57 AM
stickygreen's Avatar
'97 E320
Discount/America's tire > Costco
All else being equal:
265 will be a little better in snow and offer better turn in
285 will offer more ultimate dry grip and ride a little squishier
Old 10-13-2012, 02:07 PM
collman's Avatar
Lexus GS300
Thanks.
I decided to buy 285 at tirebuyer.com.
Old 10-13-2012, 02:25 PM
aeggroup's Avatar
2023 Range Rover, 2020 MB S450
Originally Posted by collman
Thanks.
I bought it here : http://www.performanceplustire.com/
Old 01-12-2013, 01:07 PM
kimbray's Avatar
GL450
I have a 2010 GL450 and looking to get snow tires as I have All Seaon on right now and do not work well when it snows in Colorado. I am too looking at 265 or 285s. I am thinking about going with Blizzak DM-V1s and go with the 265s as they will do better in snow. Any thoughts before I buy on 265s vs 285s for a snow/winter tire?
Thanks!
Old 01-12-2013, 01:29 PM
KYBRIGGS82's Avatar
GL350
So that being said of the 285/85/20 tires, which is the best brand/tread-wear and design for driving on California freeways and local street surfaces for the best possible ride? NO snow !
Old 04-10-2013, 06:26 PM
sqchris's Avatar
2010 GL350
Received message from MB Canada that 285-50-20 is not approved tires for GLs. What are the consequences if I install them? I am looking at Michelin or Pirellis.
Old 04-10-2013, 07:45 PM
BlownV8's Avatar
Received 1,000 Likes on 807 Posts
E55, GLS450, GL63, GLE350
Your speedo will read about 1.3% too slow.
Old 04-11-2013, 12:06 AM
kingcity's Avatar
C240
I have the same situation. Have 2011 GL350 with stock 20" rim on stock 275/50/20 tires. Just bought 19" rims intended for winter tires. Question is which tire size do I need for my 19" rims. Looking at Blizzak too.
Old 04-11-2013, 10:25 AM
BlownV8's Avatar
275/55/19. I would have gone to 18" tires for the snow. There are even fewer choices in the 19" wheels than the 20".
Old 04-12-2013, 09:53 AM
UDWANIT2's Avatar
2016 E550 Cab & 2011 GL 550 & 09 VROD Muscle & 06 Seadoo Speedster LE .......
running 285/30/24 no problems with speedo n picks up faster than stock since the forged 24s r lighter than stock 21s..
Old 04-12-2013, 10:56 AM
alx
alx's Avatar
wheel weights have no effect on speedo accuracy. if your speedo is reading faster it means your new tires have smaller diameter than the stock ones.
on the subject of 265 vs 285 - it is a trade off- narrower wheels will do better in the slush, but when pushed on the dry will understeer more aggressively. and if you have ever pushed your truck (intentionally or not) you will know that undesteer is its middle name.
Old 04-12-2013, 12:40 PM
fkong777's Avatar
07 GL450, 91 NSX, 12 Prius
the Stock 18" runs on 265.. but if given the choice I would get 285. you will have a slightly higher sidewall and better ride.
Quick Reply: 265/50/20 or 285/50/20 Help!
