Better Low Beam Question 2011 GL
The Low Beams on my GL are less than confidence inspiring having a very limited forward range. Any one have a suggestion on replacement bulb? Or?
They can be raised to give better (further) projection. Do a search on here and there are several posts on how to do it. But in a nutshell there are places on both sides under the hood and above each light where you can insert a phillips screwdriver and turn it to raise/lower the beam.
