Front Airmatic failure and repair.
Old 03-11-2013, 11:36 AM
PLATINUM SPONSOR
Exotic-metal55's Avatar
2003 CL55
First front strut was covered under warranty but second one was out of warranty, so I went with Arnott. So for around 400.00 bucks and about hour and half labor (my first time), I was abe to change the strut. I think dealer cost is about 1600 for everything but did not even ask them.
I now have a ABS/ESP warning and used STAR to check the code. It may be a left rear wheel speed sensor or wheel bearing. I found that having a STAR unit, can save a ton of money and headachs for these little codes. The GL had about 10-15 fault codes , even though most do not show up, so was nice to test and clear them all.
Anyone have to change wheel bearings yet, with under 60K miles?
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old 03-12-2013, 02:15 PM
KrustyKustom's Avatar
2021 V167
exotic metal
How many miles did you have on it when you lost the first front strut?
How about the second one?
Where did you get your STAR program from? Ebay?
Old 03-12-2013, 02:45 PM
alx
alx's Avatar
shock is 1200 retail or thereabouts. 2 hours @ 150/hour... that is what the dealer will charge you.
the esp/abs problem might be a coincidence - weak batteries tend to throw that code.
60k miles for bearings is not typical. i have seen only one go bad on the gl trucks and it was at 140k miles.
Old 03-12-2013, 03:00 PM
vntgspd's Avatar
Porsche 911
Thanks for sharing. Nice to read these stories rather than "I just left the dealer with a $1500 bill - so glad I have a warranty".
I just replaced a leaking airmatic PUMP. Cost me $370 delivered and 30 minutes to change. Meant to do a DIY but life got in the way and had no time.
I agree about the STAR. I plan to get one in the next few months.
Old 03-12-2013, 03:46 PM
alx
alx's Avatar
absolutely- if you think about diy any mercedes- a star clone is mandatory.
just dont play with the developer's mode (good that most folks dont know german)
Old 04-21-2013, 12:26 PM
jsten's Avatar
GL450
My 07 GL450 had a slow leak in the front passenger strut for about three weeks. It failed completely yesterday at 101k miles. The dealer quoted $1400 to replace it with MB rebuilt unit. They quoted $900 for the parts only for one strut? I plan to replace both front struts with Arnott units at $450 each. Anybody have experience with the Arnott product?
Old 04-21-2013, 12:31 PM
alx
alx's Avatar
Search the forum.
Old 04-22-2013, 12:49 PM
Former Vendor of MBWorld
arnottdoug's Avatar
MERCEDES-BENZ CL-CLASS
Forum members can save save an additional 10% off (up to $75) if purchasing from Arnott by using the code MBSAVE12 during checkout. Not good on core deposit, shipping or taxes (if any). Also, check out the
available online at YouTube and off the Arnott web site.
Old 04-23-2013, 04:06 PM
parkpaul67's Avatar
2008 GL450
GL 450 2008
I recently changed air shock on Left front few month ago now front drop again for second time . I was just wondering if i have a air leak somwhere in the system .Did anyone had a same problems ? i read form somwhere about air leak with photo
Old 04-24-2013, 09:23 AM
PLATINUM SPONSOR
2003 CL55
There can be air leaks but usually, it is just the next strut or air bag that has not been replaced.
__________________
www.ultimatepd.com
Quick Reply: Front Airmatic failure and repair.
