I'm in a world of confusion! (Airmatic problem)
Gl450
I have a 2007 gl450 been having airmatic malfunction problem. Started of as the car slammed, the reset and it lifted but passenger Sid is about 1" lower then Drivers side. Compressor does not turn on (but will if I jump the relay). Found the airmatic control module connections were loose, so I reconnected it and when I started it again it would turn off. I changed all the speed sensors and the rear ride height sensors. After that the car would stay on while I had the front ride height sensors disconnected. I plugged in the front drivers side height sensor and still good. As soon as I plug in the front passenger side height sensor the car shuts off. And it's giving me a message of off road level 3 can't exceed 20 mph, but the cars drives fine above 20 mph. IM GOING CRAZY! Please help!
Have the car read. Check readings for level sensors, air pressure in each shock, speed sensors at each wheel, compressor activation, etc.
You are wasting your time and money otherwise.
Gl450
I had all the parts already. So I'm just trying what I can. Before I bite the bullet with the stealership
