Found loose hose clamp MU 14
I was looking underneath the a car found hose clamp mu 14 hanging from a hole of undercover plastic. Pulled it off and started looking inside engine to see where it might came off. Saw the same clamp on a hose coming out of the power steering reservoir (green fluids). Does anyone know where other hose that is using the same clamp?
Evidently the green power steering fluid was low 6 months ago had dealer checked and topped off. Asked about the leaks they said none. There were about 10 green stain spots on my garage floor directly under the steering column area. Car still under warranty until end of Nov so will probably find a reason to bring it in to checkout the steering column before then.
