Reset Check Engine Light - 2008 GL450
Old 09-08-2013, 04:38 PM
TylerAdams's Avatar
2008 GL450
I changed my oil yesterday and everything seemed to go smoothly. When i started the vehicle this morning the Check Engine light came on. I'm not completely sure, but it seems to idle a little rougher too.
How do i reset the check engine light so I can tell if it comes back on or not. I see how-to's on just about every year but the 2008.
Old 09-08-2013, 05:22 PM
N_Jay's Avatar
2007 W211 E350 4Matic / 2008 X164 GL320 CDI
Read the code to find out why it is on.
Old 09-08-2013, 06:13 PM
TylerAdams's Avatar
2008 GL450
How do i find the code? And where do i look that code up at?
Old 09-08-2013, 06:29 PM
N_Jay's Avatar
Any good ODB reader than has CAN capability will give you the code.
Some even translate it for you, some come with a book and some point you to a web site.
Old 09-09-2013, 12:32 PM
TylerAdams's Avatar
2008 GL450
Is there a way to jumper the connector and read the flashing light? i've done that in a few other OBDII cars?
Old 09-10-2013, 10:12 AM
alx
alx's Avatar
this gm-like functionality is not available on your truck. or any other modern german car.
if you are going to be doing your own maintenance invest in a star setup
Old 09-10-2013, 10:16 AM
N_Jay's Avatar
If all you are looking for are standard codes, a $20 ebay ODB/CAN reader is a good start before investing $700+ in a Star set up.
Resetting the codes without reading them is like a Dr. telling you to take a pain killer before asking "what hurts".
Old 09-10-2013, 11:14 AM
alx
alx's Avatar
using the standard odb2/can reader is the easiest way to get really confused. lots of the main codes that get thrown are the tail of a bazaar chain of events that triggered mb-specific codes that triggered often unrelated main code which is the only one (or few) you can read with the odb2/can reader.
the star setup is $350 if you have already a laptop
Old 12-15-2013, 10:35 AM
kcmaleske's Avatar
2008 GL450
2008 GL450
So what was the result of the check engine light? I just got gas this past week and soon after the light went on. I made sure the gas cap was on tight and it was as I know sometimes that puts the light on.
Quick Reply: Reset Check Engine Light - 2008 GL450
