2011 GL450 How to Change Air Filter
2001 SLK 230, 2007 GL 450
It's been a while since I've done mine but it's not too complicated. You need to remove the crossbar and then pop the main plastic cosmetic type cover off. There are plastic housings on either side that you unscrew and the airfilters are contained under those covers.
I followed these steps from an earlier post:
https://mbworld.org/forums/gl-class-...placement.html
Very straightforward.
