Lowering Airmatic with STAR
Benz GL320 CDI
I've been researching how to lower my GL using my STAR diagnosis system (Made in China) I've read the procedure listed on the W211 forum:
https://mbworld.org/forums/w211-amg/...ts-o-pics.html
I can put the values in, but for the X164 it lists the suspension height in mm, not in voltage like described. It also doesn't say what the high and low values are. My stock levels are around (-30)mm and I can drop the car down to (-70)mm, but when I try to enter the inclination angles (within specs listed in STAR) it won't accept it. If I raise it back to (-30)mm the values are accepted...
Anyone experienced with this type of procedure?
I was either going to use STAR to lower my GL or make the brackets - but I thought I'd try this method first
05 E55
I had my car lowered with star an the ride quality was horrible, so I had them put it back to stock. Now my car is lowered with a ELM an the ride quality of the car is almost as smooth as stock. Food for thought.
Lowered is lowered. One lowering method does not produce better ride than another in the case of airmatic. It is all in your head.
Btw, lowered gl trucks ride really crappy...
Benz GL320 CDI
Thanks for your replies
Yeah, I've explored all the options available and figured that since I have a STAR already, I would try that option (least expensive...)
I don't want to slam my GL to the ground, but I would like a 1-2" drop if possible. The factory setting has a ton of wheel clearance and it looks weird IMHO. I roll on the factory 18" wheels in the winter and have aftermarket 20" for the summer...
I tried different heights in mm and different inclination angles (within listed specs) and nothing would stay - except for the (-30)mm setting that seems to be the default and is what the automatic levelling option gives you. I suppose fully lifted would be 0mm...???
Does anyone know the maximum drop you can do in mm and still stay within specs?
lowering is pretty much less air in the bags. airmatic is very slow acting (actually not acting at all) and all it does it maintains certain pressure in the system.
less pressure - less height. how you achieve the less pressure (star, elm, links) is irrelevant.
Doesn't airmatic actually use sensors on the suspension to set height, not just maintaining some set pressure in the air springs?
it does. but those sensors are just feedback how much air to be pumped into the bags. once the target height is reached pressure remains steady. the system is not dynamic/ reactive or precise like the abc is.
Benz GL320 CDI
I already know that (-70)mm and (-50)mm won't be accepted for some reason but (-30)mm will
Maybe on the GL, with Airmatic and the lift suspension button - "normal" ride height is already lowered as far as it will go...???
Anyone know for sure?
Or, anyone with an ML (Airmatic) or GL have their vehicle lowered with STAR?
I also don't see how changing the height with either a controller or in Star should make any different in ride. The spring rate and suspension angles should be exactly the same at any particular height no matter how it is accomplished.
Benz GL320 CDI
Unless you go super low and hit the bump-stops all the time over bumps - or if Airmatic has to increase air pressure to compensate for lower height...
Unlike coilspring cars, where if you cut the spring you drastically change rate.
Airmatic itself can have the Comfort, Normal and Sport options (if so equipped) - raising and lowering the car. Does this make the ride more stiff?
Or, does it just lower centre of gravity?
The rate and travel would hypothetically remain constant - the only change would be height and the wheel's alignment.
Benz GL320 CDI
Benz GL320 CDI
Does anyone know how much lower a 164 with Adaptive goes on Sport mode, apposed to Normal?
And, in Sport mode, does it still lower itself at highway speeds?
Benz GL320 CDI
Benz GL320 CDI
I would think that with ADS (thanks for the acronym!) all the sensors under the car would be the same - the only different hardware should be the dash switch, wiring and some sort of control box (or maybe just programming)
The level sensors just report height based on set voltages.
Gonna have to research this... But...
No, ADS has different shocks with (I think) electronic (Maybe pneumatic or hydraulic) connections so the control can adjust the dampening (separate from the height (base air pressure in the bladder).
I think there are also sensors to read the road surface, but that might only be on the new S class.
Benz GL320 CDI
Anyone find out info about heights in mm, compared to voltages...?
I could drop it to (-39)mm but no lower, without rejecting the inclination angles
Even still, after accepting the angles and saving - once I started to drive and stopped - it would raise back to the factory preset (-30)mm
Is the option to raise/lower Airmatic not available for the X164 on STAR...?
I even looked through developer mode - nothing there either
