Backup camera issues on Mercedes GL, 2007
I just installed all wiring according to WIS, OEM Backup camera and modulator. I also programmed Comand with Star to enable rear view camera. However, I do not get video.
The Comand monitor are turned black in rear shift position and some very opaque lines are running from bottom to top of the screen. Not sure where to look. Any ideas what can be wrong. Is that possible to test camera and modulator with voltage tester to find out if they are in a good working condition.
I measured the power that is coming from pin 4 from left rear lamp (E3 e3) to modulator and it has circuit around 10-12V. I am not sure how to measure video output. How correctly check if the rear view camera sends video signal?
Many thanks in advance.
it is a long explanation. In short, you need yo access your car and then make setting change in CGW (main module) and Comand modules with setting that back up camera is present.
2008 CLK 550 convertible
Can anybody help my sister n law has a 2010 GL 450. She says the reverse cameras are on while she's driving. The dealer has replaced the entertainment system 3 times and this continues. Any help?
