INSTALL reverse camera by yourself
I don't speak english ,so if you can not understand what I am saying plz guess
because I spend two days on installing the camera so no one would like to take video for the procedure, only the pictures I took by myself. at the very begining I was not sure if I can finish the job ,now everything is done.
anyway you have to remove the rear panel, the queue is from top to buttom
1,2,3,4 part 4 is the biggest part, you have to remove the buttom part 3 to help remove part 4
remove the reverse light cover , here you have to dig a little hole to get the line through into it, and then is the most difficult part , go through the line along the red arrow
attention the part in red circle must pull out both sides to get through the camera wire,
then pull out a little the cover of the carriage push the wire into it. at last the wire get to the fuse box
like this
the reverse camera switch wire connect to reverse light, attention + -
the camera needs ACC supply
avoid setting wire through all the car so I use wireless moulde , it is the sender,which should be placed out of the cover to enchance the signal
done
let's see the front part, very easy
one to three plug supply electricity to gps and receiver
done!
like this
done
done!
