2012 GL450 Break Wear
Old 05-15-2014, 10:41 AM
Mirsadvic's Avatar
2011 E350 AMG PKG,2012 GL450
Hey, i just replaced my front rotors and break pads. The break wear light has not reset. Is there a certain distance before it resets or is there a fast way to reset it.?
Old 05-15-2014, 05:19 PM
Mirsadvic's Avatar
up
Old 05-15-2014, 06:57 PM
N_Jay's Avatar
2007 W211 E350 4Matic / 2008 X164 GL320 CDI
You need to replace the wear sensor. It is a wear item.
Old 05-15-2014, 08:41 PM
B Marques's Avatar
2010 C300 4Matic, 2011 GL450, 2005 ML500, 2010 GL350 and 2003 SLK230
Sensor needs to be replaced too.
Old 05-16-2014, 03:22 PM
sak335's Avatar
2012 GL 350
Just to add to this to help you understand. The brake pad sensor is just a loop of wire embedded in a piece of plastic. As the brake pads wear, they also wear through that plastic and when the brake pad reaches minimum thickness it makes contact with the wire loop and breaks it. When that happens you see the light on the dash telling you to replace the brake pads.
Since the sensor has effectively been destroyed, you need to replace the sensor. Once replaced, the light will turn off by itself. If you get tired of looking at the light, you can temporarily deal with it by clipping the lead, stripping the wire, and using a wire nut to complete the circuit again. If you're not so inclined, then just replace it.
Quick Reply: 2012 GL450 Break Wear
