Diagnostics cables
Diagnostics cables
I am new to the MBWorld forums.
I have spent a lot of time on TDIClub and we had a google map where VAG-COM (VW diagnostics cable) owners could post their zip code and contact email. I have helped several VW owners in the Wichita area find and fix issues with their VWs.
I know that the MB Star diagnostics systems are a lot less common. I was wondering if there should be a similar directory here. I have one and would be glad to help other MB owners diagnose problems.
I will go ahead and kick this off.... here is a map.
MB Star locator
If you have an MB Star and would be willing to support others on the forums please add a pin for yourself (hit edit and then add a pin... put your forum name and type of diagnostics system you have and an email if you are comfortable with that). The map is public so anyone can edit it.
MB Star locator
I have been wanting to get a star knockoff system for sometime as I have a GL and a 2012 sprinter van as well. Trying to figure out which ones are trustworthy, so many on Ebay.
Yeah.... I am in the same boat. I would love to get one. I did notice that the Dell laptop is about $50 if you search for it separate (NO VMWARE). I will probably get one soon.
startek info..
If you have not already gotten a subscription to Startek info you should. Full parts breakdowns with part numbers and assembly codes.
Nice as you put your VIN in there and it will populate your equipment. I think over the near future the online tech know how will begin to build as these cars get into the hands of people who are hobbyist wrenchers.
Had my 2011 GL350 for a year and a half, love it.
Thanks! So far I really love it.... Rest assured any work I do on it (that isn't already documented) I will try to provide a write up.
I am an Electronics designer by profession and I would love to make up a little linear actuator based, android controlled, ride height system so you can adjust your height from your phone over Bluetooth.
I used to be an Electrical Engineer, (LOL) but now I resist the urge to do things like that.
My only mods so far was to make the under-dash power outlet selectable between switched and normal (almost) always on, and to add a charging connector at the grill to plug in to battery maintainer.
I want to install an AC Inverter under the middle row seat (Maybe where the DVD payer goes)
Hence the problem with way too many things today!
Why not build a CAN interface and use the steering wheel shift levers to toggle the height up and down?
Because then I would have to integrate into the MB system and I don't really have the information to do that.
It seems really well built and after a little confusion with the key it seems to work well. I did make an image of the drive before I put it in the laptop (in case it dies on me anytime soon).
The number of parameters available in this thing is amazing.
questions..
Did you get all of the cables with it? Did you supply the Dell computer or did you use something else?
I have watched the guy at the dealer use it and it is crazy comprehensive. I need to get one...
If you are close to Wichita I can show you what I got
