what is service #2 under a "C" service due
GL 450, 2011
I followed a post on here to see which services are due for the "C" service. after going to the mileage/trip screen, i pushed the reset 3 times and then found service 2,3, and 12 are due. the list i found from a previous post stated 3 is the engine oil and filter, 12 is spark plugs, but I did not see what number 2 is? service 1 was not listed as well.
Does anyone know what is to be done for service 2 and also for 1 if it exists?
Thank you, we have a 2011 GL450 with 66,700 miles on it.
OC Big B.
OC Big B.
I can't seem to find an explanation of the Service 1 or 2, but checking the Maintenance Manual does show spark plugs and brake fluid flush @ 60k mi. Otherwise, it's the usual stuff: engine oil/filter, wipers, cabin air filters, rotate tires, check brakes, check v-belt, check coolant level, etc.
GL 450, 2011
2010GL550
Thank you for your reply. I guess I will have to assume the service #2 is something basic like you mentioned. Probably will tackle the service this weekend.
OC Big B
OC Big B
