Vacuum leak, what does this connect to?
1995 e320 wagon, Land Rover Defender
I've been dealing with a P0410 code for the last 6 months. I had a "all german auto" kit installed to fix if I remember correctly was a P2004 code. I have had a P0410 code since the work was done. I was goingto check for vacuum leaks and found an unconnected hose coming out of the manifold...I can't find where it goes.
I plugged the hose and cleared the 0410 code to see if it does the trick. Would rather hook it up where t is suppose to actually go.
Any help is greatly appreciated.
