GL Air Suspension Question.
Old 01-13-2015, 07:35 PM
nievesa1's Avatar
2007 GL450
I have a 2007 gl450 with around 90k miles, i notices the back passenger drops down randomly. if i go to unlock it it will raise itself back up, sometimes it will stay up for days sometime it will drop 20 min after i park it.
My question is, what is failing and is it necessary for me to bring it to Mercedes to have them tell me the exact issue? i plan on replacing both air shocks with arnott air shocks in the back i just don't want to buy these parts for nothing to find out its something completely different. Any input would be greatly appreciated.
thank you!
Old 01-13-2015, 09:26 PM
Cooljust's Avatar
2008 GL450
https://mbworld.org/forums/gl-class-...r-springs.html
Old 01-19-2015, 11:18 PM
noud's Avatar
99 E55, 00 S500, 01 CLK55, 01 E320, 04 E320
Happened to me. Your air bag is leaking. You do not have to replace them in pairs, but you need to replace it as soon as possible, because you are over using your compressor right now. I went with OEM bag, if you feel more arnott then go with it =)
Old 03-02-2015, 08:08 PM
memphis c350's Avatar
2008 mercedes c350
I've order (1) arnott bag for my left rear and plan on doing the install myself.
My question is. Should I replace both or just wait until the other starts to leak.
As the writer stated above I love the ride. Whem working a double I generally have to roll down the window to keep from falling asleep (with a ride this smooth). The dealer suggested I chamge both out at the same time. But with the install being so simple and arnott having an ample supply I didn't see the need to purchase 2.
Old 03-02-2015, 08:33 PM
noud's Avatar
You dont have to change them in pairs. Also, second one might not leak at all next couple years=)
Old 03-03-2015, 06:17 PM
2008 mercedes c350
Great. Also is this something I can do in garage with a floor jack and stands or do I relly need a car lift like in the aronott video
Old 03-04-2015, 09:08 AM
N_Jay's Avatar
2007 W211 E350 4Matic / 2008 X164 GL320 CDI
I am in the same boat without a lift.
The only hard part from what I can see, is getting to the air line fitting which is on the inboard side of the bag.
Make sure you let the car down a little onto the wheel before starting up the compressor.
Then let it down slowly so the car can take over without dropping it on a not filled bag.
Quick Reply: GL Air Suspension Question.
