GL550 Windshield Replacement. Which one?
14 GL550; 14 E63s
So our Gl550 front windshield has a 10" crack that has formed from an existing rock chip that was supposedly sealed years ago. So looks like it needs to be replaced. When I'm going through the Safelite estimator, it gives 4 different choices. How do I know which one?
I do know that my V1 radar detector won't work on my windshield unless I put it down at the bottom-center of the glass where there is a little section you can see is either un-treated or coated differently. So I assume it's an IR glass or something. Is that the last option with the green tint/laser deletion area? That would make sense, but just checking.
Also, any harm in getting the cheaper glass? Not sure what benefit the more expensive glass gives us.
Blue Tint
Rain Sensor, Solar, Encap, W/Third Visor Band
Green Tint
Rain Sensor, Solar, Encap, W/Third Visor Band, soundproofing
Rain Sensor, Solar, Encap, W/Third Visor Band, Solar Coated, W/Compass and Laser Deletion Area
Blue Tint
Green Tint
This is just my theory on Safelite glass. USAA insists on you using their glass. Cheap replacement glass I'm guessing! Most of the glass they make themselves. It cracks easier, nicks easier, chips easier and pits easier. USAA does not care, in there eye's and pocketbook they have made you whole again, case closed have a nice life! Have not been real happy. I suspect the cheaper shops just order from them so you are just getting another cook in the kitchen.
I personally have had nothing but issues with the non OEM glass they use. I've complained and complained to USAA and all has fallen of deaf ears. The other issue is their install looks like a 5 year old did it. Sealant dripping on the surrounding molding. Try getting the black goop off the gray material that surrounds the glass. Not happening! Again they use cheap molding that cracks, splits and does not hold up. In a few years it looks like total crap. The last install was a train wreck. On my Subaru they sliced into the dash pad with the razor knife. They paid to have a new one installed. On my mini van they broke the cowling and the wiper motor arms. They said nothing and sent me packing until I turned on the wipers and they did not work but made a horrible noise. Took the van into Dodge they asked if I had the windshield replaced. Yep. They showed me where they used duct tape to tape up the arms. I called USAA, which turfed it right back to safelite who tried to tell me to suck on a lemon. After many calls and climbing the food chain it was fixed. Once you swap out a window it's never the same again. I would suggest you thoroughly go over the job before you leave the shop.
14 GL550; 14 E63s
Yeah, I'm not too impressed with the USAA/safelite relationship. My plan was to go elsewhere, but I just wanted to be knowledgeable so I got the right window. My MB dealership actually recommended a local company that does all their installs and they order OEM parts. It's like 890 bucks! My deductible with USAA is 200 so hopefully they will cover a non-safelite installed window. We'll see.
Received 1,001 Likes
E55, GLS450, GL63, GLE350
I must not be the only one complaining about this company?
SAFELITE = Crappy Product/Job!
Nothing but issues!
On my Montero which has a windshield like a Jeep = Rock catcher. They were the only ones installing my glass as that's who USAA uses. 1) Dropped glass on hood! Dent, they paid Dent Wizard to pull it. 2) Had the glass replaced so many times they would not warranty the job as they said the body where the glass sits was rusted. It was from the removal tool they used that tore up the channel.
On my other Subaru the rubber molding around the glass shrank and they refused to fix it. Again siting it was not there repair. Yet it was there name stamped in the glass.
If you can get USAA to use the factory glass go for it.
Nothing but issues!
I did not ever have a problem with Safelite's work but I did have a problem with the crappy glass that they used on my GL. The slightest rock hit would cause the glass to star and or run.
Sorry to rant all over this! Most people don't care! I do and care! I can spot a non OEM piece of glass. Once you replace the factory glass it's never the same.
The problem lies with the insurance companies. You pay retail prices for coverage, yet they want to do wholesale work and less when it comes to pay out. They make you whole again at your expense and that's all that's required. They don't care how many times you have to get pissed off or take it back, they look at it as they did their job and off to the next victim! It's a racket!
SafeLite is cheap at everything! The others are not any better but you would think not since it's their bread and butter.
You're paying for it in the end through your premiums, so why not get the quality that one expects!
