GL320 excessive boucing
Old 05-04-2015, 04:52 PM
hawk1996's Avatar
2008 GL320
Hi, we just got a 2008 GL320 CDI and really like it a lot. The only issue we have is at highway speeds when you go over a bump there seems to be a lot of bouncing and swaying side to side. I don't think that is normal, but never have driven a GL320 I was not sure. Any advice would be great.
Thanks,
Old 05-04-2015, 07:44 PM
Fourdiesel's Avatar
2008 GL 320 CDI, 2004 VW V10 Touareg TDI
Shocks
Old 05-05-2015, 08:51 AM
a2j
a2j's Avatar
2008 GL320CDI (265k) & 2017 GLS450 (120k)
More likely your rear struts leaked out and need to be replaced. I've done it twice so far.
Old 05-05-2015, 09:43 AM
hawk1996's Avatar
2008 GL320
Thanks for the reply's. Thats what I was thinking could be the problem, it looks like there are 2 version one with ADS and one without, how can I tell which one I need?
SHOCK ABSORBER.
Required: 002
REAR LEFT AND RIGHT
489
[20010326 - 20010326]: AIRMATIC DUAL CONTROL / AIR SUSPENSION SEMI-ACTIVE
SHOCK ABSORBER.
Required: 002
REAR LEFT AND RIGHT
214+489
[19951002 - 20000407]: ADAPTIVE DAMPING SYSTEM (ADS) WITH SKYHOOK
Old 05-05-2015, 10:02 AM
a2j
a2j's Avatar
SHOCK ABSORBER.
Required: 002
REAR LEFT AND RIGHT
489
SHOCK ABSORBER.
Required: 002
REAR LEFT AND RIGHT
214+489
GL320 don't have ADS, but I could be wrong. Are you able to switch your suspension from Sport to Comfort? button between ESP and seat warmer. If you don't have this feature, you don't have ADS.
Old 05-05-2015, 11:35 AM
hawk1996's Avatar
2008 GL320
My console looks just like the one in your picture, there is no button for Sport/Comfort. So it looks like I do not have ADS.
Thanks for the help a2j
Old 05-05-2015, 01:38 PM
N_Jay's Avatar
2007 W211 E350 4Matic / 2008 X164 GL320 CDI
Non ADS.
My leaking shock was obvious. (The thing holds a LOT of fluid)
Old 05-06-2015, 09:50 AM
a2j
a2j's Avatar
That picture is not mine. I googled it. You are welcome.
Old 05-06-2015, 10:55 AM
N_Jay's Avatar
"Sport/Comfort" is the button with eth shock absorber picture.
If you have that (and I doubt you do) then you have ADS (and get the honor of paying twice as much per shock)
P.S I just did a rear shock, and give yourself some extra time to disassemble that rear cargo space interior. It is not hard, but does take some careful time so you don't loose or break any clips.
Having a few spare clips is worthwhile. (I lost one on reassembly, and the parts store replacement was not a good fit)
Also, my shock did not come with new hardware, and you are not supposed to reuse the interference (crush) nuts.
Both the two nuts at the top and the one through the suspension are crush nuts.
I just reused the nuts and added locktite blue to the threads.
Quick Reply: GL320 excessive boucing
