2009 GL550 - Issue or not
2010 S 550
60k miles. Drives great. Wife's co-worker noticed front right a little low. Not a tire issue. No warning lights inside, so I assume manageable for now.
Any ideas or suggestions? Also, we have an extended warranty, would you think the problem would fall under that or is it possibly a wear item?
TIA,
TIA,
2010 S 550
So last night after she arrived home, I had her park on a fairly level surface. I measured various heights around the vehicle in front, the fender well, a sensor, the front license plate holder and same on opposite side. The opposing side measurements were well within reason of the same height. This was after driving for 30 mins. I then raised to max level and remeasured. All 5 points raised equally. Let the vehicle sit for 30-45 mins and remeasured. All same. I think she must have been parked in a slightly uneven parking spot as all appears good. What do you think?
