GL320 Check Oil at Next Refueling
Yes.... I know.... search.
Here is what I know. There may be either a new bracket or sensor that will eliminate this problem. Does anyone know the part number for the new bracket? Is there an oil pan gasket kit? Part numbers for the gasket set?
I have checked the dipstick multiple times on a level surface and the level is fine. I have added some just to be sure. I have changed the oil warning level to +3 and -3mm with no change.
